ok heres the story. i installed a pedal assembly in my 92 gt. got everything hooked back up. then i start the car and the idle is really rough and i hear a hissing noise coming from the brake pedal and the brake is hard to push down. but when i push the brake down the noise gets quieter. i asked a friend and he says that it is the brake booster and i need to remove it and check the valve. does that sound right and if so how do i re-adjust it. it was working just fine before i installed the new pedal assembly. any feedback is greatly appreciated.
When you say assembly .. do you mean just the pedal assembly or did you replace the booster & check valve also. Just look on the booster and you will see a check valve. I would start with listening around that area for vacuum leaks. Could also hook a vacuum gun upto the booster and see if the diaphram holds any vacuum. Simply first step is to get a new check valve.
