Brand new gas tank.....
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date May 27, 2008
65fastbackresto
1,229
AR
May 27, 2008
  • May 27, 2008
And my gas gauge dont work.....
All I did was unplug it and plug it into another one, any ideas?
It was a 65-66 gas tank kit from CJ Pony Parts.
Pbum5
515
Minneapolis, MN
May 27, 2008
  • May 27, 2008
Check your fuses.
It's worth a shot.
9
96 DOHC Cobra
542
Cerritos, CA
May 27, 2008
  • May 27, 2008
Ground wire?
65fastbackresto
1,229
AR
May 27, 2008
  • May 27, 2008
I`ll check the fuse but....
was there a ground wire on the tank? I dont remmember seeing one, although there was a clip thing on the upper right hand side looking down on it......I thought it was just holding the wire down.
Tim65GT
1,149
West Texas
May 27, 2008
  • May 27, 2008
Unplug the sender wire and ground it.
When you turn on the ignition, does the gauge move?
If so, the problem is in the sender. Drain the tank and pull it out to see if it move freely. put a ohm meter on t as you move it through it's travel. The ohms should read 8-12 ohms full and 70-73 ohms empty.
If the fuel gage doesn't move with the ground test, check the gauge, wiring or the instrument panel voltage regulator.
BarnStang
1,260
Hagerstown, MD
May 27, 2008
  • May 27, 2008
Exactly. Also, it is possible to put the sender in upside down. Make sure that didn't happen. You would know that pretty quick caue the fuel hose would be really hard to connect cause the fuel outlet would be pointing the opposite direction from what the old one was pointing...
65fastbackresto
1,229
AR
May 28, 2008
  • May 28, 2008
Everything was in the right direction.
I used POR15 in the entire trunk area, is it possible the tank isn`t grounded good cause it`s sitting on POR15? Or would it ground itself with the screws that are holding it down?
I`m trying Tim`s idea after while, we`ll see where that goes.
C
chromedog
554
worlds center for speed
May 28, 2008
  • May 28, 2008
when i checked this post out last night, my first thought was "no ground to the tank.." do this first: run a jumper wire from the sending unit, to a good ground. if you get a reading, you need to ground it. you dont need to remove the tank, just trade one of the self tappers holding the tank down for a machine screw with a nut, and run a jumper from there to a ground.
68 fuel gauge maxes out at half
  • connella08
  • Sep 5, 2025
Classic Mustang Specific Tech Sep 8, 2025
connella08
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
