I am going to pick up my engine from the builder soon and drop it in. What are some tips for start up and break in. The engine will have Valvevoline 10W30 in it. I am planning to change that at or before 500 miles.
What RPM range is appropriate for a roller cam engine break in? Should I drive it hard or just keep it under control?
Only problem I had with my motor at first was vacuum leaks. I forgot to put one of the plugs on the upper inmtake ports and I had a leak at the lower. I still may have a leak and I think I have to mill the lower intake a little to mate up better. I remember hearing a high pitched squeeling noise on 1 or 2 of the intake bolts when I was torquing it down. It may have been binding due to the lower not being lined up 100%. I am gonna do new head and intake gaskets eventually along with head and intake studs and have the lower milled if needed. I also been thinking of putting the 302 back in and selling it
