breakin up???????
l3urnin0ut88
9
question,,,today i installed 1.7 roller rockers,24lb injectors,c&l 73 mm mass air unit,and a bbk adjustable fuel pressure reg. on my 88 gt,i set the fuel at 38-40 lbs, whats happening now is at like 5000 rpm its breaking up,it did not do this before.,,any clues to why it is doing this..??????,,,it also has a gt-40 intake ,e303 cam,70mm throttle body,if this helps any,,,im confused,,,lol?
yes it has a brand new sample tube for 24lb injectors,and i did set it with the vacum line of,,,it seems to work great other then it breaks up aaround 5000 rpm,,,kinda sounds like a rev limiter??
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
Or you can grind down the outside of a 7/32" deep socket untill it fits.
