Some of you may remember my post about burning up my stock calipers at the road course in April. I replaced the front brakes with a 4 piston, 14" rotor Brembo setup.
http://img.photobucket.com/albums/v727/jlisle01/AfterBrakes001.jpg
The install was easy, very high quality parts and kit. I also ordered and installed (or tried anyway, more on that later) a brake cooling duct kit from Steeda. Also in the mix was a brake temperature paint kit to get an idea of what kind of pads I was going to have to run. I got the stuff installed Saturday and went out to the track Sunday for "testing". The brembo's kick butt. Way better pedal feel and absolutely no fade at all. The temp's never cracked 750 degrees and the pedal stayed as hard as I did all the way through the sessions. There was a couple of guys out there in an '04 ZO6 and the last session one of them rode with me. He was kind of surprised with the brake power and said I had way more brakes than the vette. All in all, I am very happy with the Brembo's.
http://img.photobucket.com/albums/v727/jlisle01/TrackDayApril014.jpg
http://img.photobucket.com/albums/v727/jlisle01/TrackDayApril006.jpg
The cooling ducts are another story though. I went with the Steeda kit because, to tell the truth, after the Brembo's and the new wheels (to clear the Brembo's) I just flat didn't have the money for the $400 cooling ducts and new lower grill from Agent 47 that I wanted. Steeda said their kit was made for their own front fascia but that it would fit the stock fascia. I have pretty much a whole Steeda front suspension on the car and I've never had a bad experience with their stuff so I opted to go cheap. MY BAD. It took me about two hours with a dremel tool to cut the openings for the billet ducts only to find out that there are hard fluid lines (AC or trany cooler, I was too irritated to care which) straight behind the lower grill openings that got in the way of the hose routing. The hose Steeda supplied was cheap plastic stuff that's not very flexible and I spent the last two hours of Saturday daylight trying to route the hoses. I eventually got the drivers side kind of half on and just flat gave up on the passenger side completely. I'm going to end up ordering some 3" silicon hose from Pegasus Racing that I hope will be more flexible. I do like the billet aluminum ducts in the grill and it's a good thing, because the ducts are the only part of the kit I'm going to end up using.
http://img.photobucket.com/albums/v727/jlisle01/AfterBrakes002.jpg
In conclusion: Brembo's....
, Steeda Ducts....
Brakes that don't catch on fire....priceless
