What would be better for my 306 on the street, brodix street head or afr 165's? It needs to be completetly streetable and torquey as hell.
.They 185's are arguably the best emissions legal head you can buy out of the box. They will benefit you if the rest of your intake track is oriented for high rpm, or if you want to boost down the road, or want more cubes latter.ms93gt said:Well what would I benefit more from, the 165's or the 185's? I'm getting a custom cam so maybe ed could grind me something a little smaller so I won't have piston problems. The pistons I have now are speed pro forged with 10:1 compression if that will help with the question.
. RPM heads have 1.90" or 2.02" I believe, so no help therems93gt said:Well the guy I bought the motor from had edlebrock peformer rpm heads on it with a trickflow stage 2 cam, (which I have now). But since you say the 185's are for high winding then maybe I should just get the 165's cause I need torque because this will be a street car.
.Rick 91GT said:What is the PT# of your piston, this will tell me if the 185 will fit.
If you plan to go with any type of healthy cam, or custom cam you will need upgraded springs.
TrophyHead said:What does PT# mean?
For a supercharged street car which head Brodix ST50 or AFR165? I never hear anything about Brodix.
