buck, spit, loss of power
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
93 lx, 5 speed, 65k
was in 4th up a slight incline doing about 45 when the car bucked a little like it was hesitating to make it, then I heard some popping in the exhaust, then it felt like a 6 cylinder. took it home and it idle okay.
at first I thought clutch, but the rpm's never shot up. this car is stock and rarely driven. i.m guessing clutch or fuel :shrug:
hasn't had a clutch in 10 years but it's the 2nd with only 65 k
ideas?
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
Do not jumper anything to the single black connector. It is the power for the under the hood light. It is in another bundle of wires near the windshield wiper.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
My car bucks similarly to how you described it. I pulled the codes and turned out both my TPS and O2 sensor are bad. I replaced the TPS and that helped the bucking but it still does it. I'm checking out the O2 sensor tonight. I'll let you know how that goes.
I don't know what codes you pulled but my car had similar issues. I replaced the O2 sensor, cleaned the contacts on the ECT, replaced some suspect vacuum lines and now it runs smooth with no idle problems.
