Ok here is a deal
I was going to build 347 using stock 302 block and then put some boost from turbo ,but since 347 and boost will kill stock block quickly i decide to stick with 306 and turbo
Local machine shopw will do machining stock block and local Ford engine bulder will install all parts
Now questions are:
What parts i gonna need to to complete this whole project (main gridle.......,i talkin about bottom end,so top end and fuel parts are left for other thread)
Also should i go with CHP or DSS kit
Boost will be whatever i need to make around 450HP just to keep safe and crack block
Heads i gonna use are mine TFS TW and does anyone knows what CC pistons i need to made 9.0:1 compression with TW heads
Also what crankshaft i should use one that need 50,28 or 0 oz ballance
BTW don't try make me go with aftermarket block because i wanna stick with stock block for some time
Thank you
Now questions are:
Thank you
