  • SN95 4.6L Mustang Tech
Building for Boost, Whats Needed.
  • Thread starter Thread starter HoustonGT
  • Start date Start date Mar 3, 2004
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Mar 3, 2004
  • Mar 3, 2004
Hey guys, i don't have the money to buy a supercharger right now or anytime soon really. Im going to go slow and do it right and not just stick the SC on my stock block because i want to drive around on 9psi or more daily and be confident that my engine won't blow. So what parts need to be forged/replaced? I was thinking of getting the SHM Rods/Pistons/Rings/and Rod Bearings all for 1450 shipped. What else shouild i replace to allow me to run a 9psi SC and most likely go to a smaller pulley for alittle more boost and still be completely safe?
-Im talkin about engine components, not fuel or exhuast stuff.
THANKS
NiteMareGT
300
Danville,VA. USA
Mar 4, 2004
  • Mar 4, 2004
Just to let ya know, you can run up to 10 psi on your stock block with no problems. The secret is a good tune, to keep all your variables in order.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Mar 4, 2004
  • Mar 4, 2004
But isnt that just running on borrowed time? I'd like to get a Vortech and then a good air-air intercooler and run a smaller pulley.
kirkyg
3,568
Beaumont, TX
Mar 4, 2004
  • Mar 4, 2004
Why not save up for a 6 psi Kenne Bell kit. It should handle fine on a stock block. Expect 340-360 rwhp range depending on boltons and instant max. boost off idle. Can't beat it
kirkyg
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Mar 4, 2004
  • Mar 4, 2004
kirkyg
Id rather push like 400-425rwhp. The Kenne Bell would be great, id just like to get a smaller pulley and run more safely.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 4, 2004
  • Mar 4, 2004
just get the 9 lbs intercooled kit and get a good tune , most people are seeing 410 to 425 rwhp , safe tune is the key to making it last . go for it dude
kirkyg
3,568
Beaumont, TX
Mar 4, 2004
  • Mar 4, 2004
Well more power to you...id go intercooler if you can afford it. But the 6 psi will not produce as much power and will be more conservative on your powertrain and thats what i thought you were looking for.
kirkyg
1fast03pony
749
New york
Mar 4, 2004
  • Mar 4, 2004
What i would do is buy a complete forged rotating assembly, upgrade the clutch, do some air mods like headers and plenum/tb... and then when you decide to get the blower, the motor will be set up for it. then just get a good tune. This way, you can run 9 or 10psi with no worries
R
Roush21
348
  • Mar 4, 2004
I ran 10lbs of non intercooled boost on my cobra for the past 2 1/2 years and never had a problem and its still running on the superchips tune (getting dynoed this spring, dont drive it in the winter) You can pick up a vortech kit for an inexpensive price and run the 8lb pulley like i am and get an anderson racing powerpipe and get 10lbs of boost. Thats what i have an i get 10 lbs of boost. you dont need internals unless your running more than 10-12lbs but an intercooler/aftercooler would definetly help if you wanted to go more than 10. just my $.02
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Mar 4, 2004
#10
  • Mar 4, 2004
  • #10
Very good advice guys. Thanks for the help and this is exactly why i come to Stangnet
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
