i am looking at the crane rockers part#44746-16 from summit 1.7 ratio ?mine 95 5.0L 5spd there 5/16 stud right are they going to be good our you guys know better ones ???
I have the same pedestal-mounted Crane 1.7 roller rockers 44746-16. The choice will depend on that head/cam/intake mods you're planning later on. If you're looking for power at 6000+rpm, you're gonna need a longer duration cam with more lift and stiffer valve springs, in which case a set of adjustable stud-mounted rockers would be a better choice.
The pedestal-mounted rockers will do fine if you're going to stay below 6000rpm and you're building the engine for torque at lower rpm.
will the stock valve covers work with the crane cam rockers ????? i have trick flow upper and lower with 3/8 spacer or do i need different valve covers
Correct. It's a GT and I have the 1.7 ratio Crane RR's 44746-16. If I had a Cobra, these roller rockers would have already been in the engine as standard. No clearance issues with the stock valve cover and stock gaskets.
