C&L mass air meter
fivespeedsteed
Oct 17, 2003
748
22
69
Richmond, VA
i just ordered a 76mm inlet tube and 76mm maf, ive heard that they arent as good as the pro-m units becasue of the offset reader thing. should i try the c&l out or just sell it once i get it and get a pro m one? i think its to late to cancel my order.
alright the way the MAF works. i will try to keep it simple
like all the other sensors that work along with the EEC computer. the EEC throws out 4 volts to each sensor, and the sensor will send a return voltage, it will be 4 volts or less depending on the condition of the sensor. like the coolant temp sensor, when the coolant heats the sensor up it will allow more voltage through it and when the EEC recieves more voltage back it knows that as its getting warmer..
The MAF works in a similar way. it uses the two wires on the sensor, one is ambient temp and the other is heated up, depending on how much you have flowing into the engine determines the return voltage back to the EEC. the more air that flow through the MAF, the cooler the wires and the cooler the wire the more voltage that is sent back to the EEC (more voltage needed to keep the heat in the wires), the EEC takes this as more air and proceeds to add more fuel.
the stock EEC is programmed for 19lb injectors, without a chip or any tuning, it will ALWAYS think its running stock 19lb injectors, unless you have a cobra etc etc.
the aftermarket mafs, like C&L and Pro-M are pretty much fooling the stock EEC to get the fuel you need.
the way C&L does this is....
C&L allows you to use the factory sensor and with their meter, you have the removeable sampling tubes ( the small tubes where part of the air comes in to cool the MAF wires). to "calibrate" for larger injectors you change the tubes inside the MAF, to a smaller tube, a smaller tube means... less air will go into it, less air will not cool the MAF wires as efficiently as more air. since the wires arent getting cool. the EEC is thinking that its not getting as much air as it actually is, so it doesnt throw in as much fuel and the engine will run better hopefully. but the accuracy of these meters come into question using this setup.
the Pro-m instead of changing the tubes. the actual sensors are modified to send out altered voltages to the EEC.
say you have a 36# injector, it can flow roughly double what stock injectors can ( its less than double but its just for an example)
with the Pro-m you will get a "calibrated" sensor. which is changed to send different voltages. so with an injector flowing twice as much as stock. you would want the sensor to send half the voltage to the EEC, which would cause it to get the right amount of fuel.
BUT the cons of these setups. using both setups fools the EEC into thinking its not running as hard as it actually is. the MAF is very critical in determining load%.
by using the C&L your getting less air to the sensor which shows up as less airflow which to the EEC means that the engine is working as hard which = less load. and if the computer is running with less load it uses a totally different spark advance curve.
same with the Pro-m, less return voltages means less air the EEC, which = less load. so again its not using the right spark advance curve.
so the aftermarket "calibrated" mafs may work pretty good, but your actually hindering your spark advance. and maybe losing some power.
i run a C&L meter using 19lbers. i didnt really notice a difference from stock. maybe a little better breathing but not much.
using the C&L or Pro-M arent really the IDEAL ways to upgrade injectors. the best way to do it is though a computer tuner. like the tweecer or other stuff. where you can actually go into the factory EEC and tell it exactly what injector its running, and you can set your MAF transfer voltages and use any size tube or meter or whatever you want basically.
IMO the C&L and Pro-M and other mafs like that are only around for the average joe to upgrade the diameter of the MAF and have it run pretty good. the average joe really doesnt get into the computer tuning sort of stuff.
hope this helps you out, like i said i am running the 73mm C&L/vortech meter with stock injectors it runs about the same as stock, no real power gain.
My .02, the 76mm C'n'L on a stock or mostly stock 5.0 is as good as it gets out of the box.
I ran onewhen stock motored and had perfect fuel curve/ratio and made 232rwhp and got into the 12's... (N/A)... no need to sell it and grab another off the shelf unit.
You should do ok with a C&L if you keep the stock airbox.
using a CAI
or cone filter mounted directly to the MAF
can cause issues with any meter, but problems seem more likely with the C&L's.
good luck,
jason
