c&l sample tube
yea you could get thoses codes because that means a lean condition, thast because the sample tube is calibrated to fool the ECU so that sample makes that the ECU pulse a little less the injectors for compensate the more fuel delivery in the 24 lbs injector but because you have a 19 lbs then you are going to have a less gasoline that you need, get a sample tube for use whit 19 lbs and you are set
ever heard of punctuation?
That gives me an idea - I have both 19 & 24 # sample tubes on two 76mm C&L MAFs and 2 Mustangs - one with 19# injectors and one with 24#. I could try switching them around with each other to see if I get better fuel mileage by tricking the computer into going lean. Anybody have any experience with this? I have gotten a best of 29mpg at a steady 70mph on a extended highway trip with no stop and go on my 24# injectors with matching 76mm C&L 24# tube with lots of other mods.
While it does sound promising at first, this isn't a good plan...
The ecu has a correction ability for the fuel metering. If the O2 sensor is seeing a lean condition, then the ecu will simply increase the pulsewidth until the mixture comes back to stoich.
Best case scenario, swapping sample tubes as you have described will have ZERO net effect.
Worst case scenario, is that the lean condition is out of range of the ecu's ability to correct, and you start having detonation issues. If you have cats, they could be damaged as well.
It would be best to use the correct sample tube, and look for MPG gains elsewhere.
jason
