Progress Thread C3W… A9L… A9P?
  • Thread starter Thread starter t1_5.0
  • Start date Start date May 14, 2024
T
t1_5.0
18
California
May 14, 2024
  • May 14, 2024
Hello everyone, I recently bought a 93 gt convertible. I noticed it used to be an automatic by the way it was modified to fit the manual shifter. Today I looked at the ECUand I have a C3W. I thought automatics were A9P and manuals were A9L. Is this something I should change? Is the C3W fully compatible with a manual if that’s what came with it as an automatic or is that something they might have swapped when they changed it to a manual or should I replace it with an A9L?
Thanks in advance everyone!
AeroCoupe
6,102
4,200
183
Claremore, OK
May 15, 2024
  • May 15, 2024
1988 MANUAL 8LD
1988 AUTO 8LF
1989 MANUAL A9L, A9S
1989 AUTO A9P, A9T
1990-92 MANUAL A9L
1990-92 AUTO A9P
1993 MANUAL A3M
1993 AUTO C3W
1993 COBRA X3Z
You can use the C3W ECU with a manual transmission as long as you use a manual trans O2 harness or rewire the auto trans O2 harness for a manual trans.
Good thread on it here:
Drivetrain - Can I Use A9p Ecu With A T5 Manual Trans
Doing a t5 swap in a 93 notch. Did a 5.0 swap on this car and used a AOD. Now I am collecting parts to do a t5 swap and I thought I read a while back you can use a a9p ecu on a 5 speed. I can pick up a a9l local for $75.00. Would it make sense to just change out the a9p to the a9l, what all is...
stangnet.com
Mustang5L5
Mod Dude
Feb 18, 2001
43,305
18,010
224
Massachusetts
May 15, 2024
  • May 15, 2024
Actually, he can use the C3W as long as he doens't change any wiring and leaves it configured for the AOD ecu.
If he swapped to the A9L, he would need to repin the O2 sensor harness foe a 93 manual car, and swap to the manual trans harness (or just add the two NGS wires and tap into wiring in the driver's kick panel). That last harness is debatable in terms of how necessary it really is.
Reactions: General karthief
T
t1_5.0
18
California
May 15, 2024
  • May 15, 2024
Okay cool, so as long as I keep the automatic O2 sensor harness I shouldn’t have to swap the ECU.
Mustang5L5
Mod Dude
Feb 18, 2001
43,305
18,010
224
Massachusetts
May 15, 2024
  • May 15, 2024
If the car is driving fine as is, don't change a thing.
Lets say the ECU fails down the road and you get your hands on a good A9L. That's when you need to pay attention to a few things.
AeroCoupe
6,102
4,200
183
Claremore, OK
May 15, 2024
  • May 15, 2024
For some reason I have had that in my head wrong for a few years then. Good to know for sure.
KRUISR
1,860
993
143
May 16, 2024
  • May 16, 2024
I think all I did was put a jumper in the trans harness because my trans didn't have a neutral safety switch. Otherwise left everything else alone.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
May 16, 2024
  • May 16, 2024
AeroCoupe said:
1988 MANUAL 8LD
1988 AUTO 8LF
1989 AUTO A9P, A9T
1990-92 MANUAL A9L
1990-92 AUTO A9P
1993 MANUAL A3M
1993 AUTO C3W
1993 COBRA X3Z
stangnet.com
You left out the 89 manual convertible A9M. It's a weird one that comes up every once and a while.
T
t1_5.0
18
California
May 22, 2024
  • May 22, 2024
Sounds good! Thank you
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
