Cai, Tb, And Maf Suggestions...
  • Thread starter Thread starter Jrodstang87
  • Start date Start date Mar 10, 2016
  • 3
  • 4
First Prev 3 of 4 Next Last
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Mar 11, 2016
#41
  • Mar 11, 2016
  • #41
Here is some documentation on it.
https://www.diyautotune.com/support...application-docs/1988-1993-ford-mustang-5-0l/
Ignore some of this. I will explain later
This is the kit.
https://www.diyautotune.com/product/diypnp-ford-60-pin-eec-iv-unassembled-kit-no-connector/
You will need to source a connector from somewhere, I used one off a junk ecu it requires desoldering the connector from the stock board.
You can wire anything from this unit, I use it to trigger my fan relays (low and high speed). And a shift light. So really the options are limitless.
Jrodstang87
41
Mar 11, 2016
#42
  • Mar 11, 2016
  • #42
This is the kit.
Interesting. I just browsed through some of that quickly. I will have more time later. But basically you DE solder the male connector from a stock ecu and solder it to that and it is the new ecu? Does it matter if the end you use if from a MAF or SD car?
Sounds like something I can do, not that I have any tuning experience but I am a master tech So i should be able to handle that. And I have heard the auto tune is great. Not bad for the price
As far as wide bands go I don't have any experience with them. Can you replace your 02 sensors with them or do you weld in a bung and use them separately?
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Mar 11, 2016
#43
  • Mar 11, 2016
  • #43
You will have to build the entire ecu from parts. Before you freak out, it's easy and the instructions are good. You can use any 60 pin ford eec connector that will plug into your harness.
I WILL HELP YOU TUNE THE CAR. Lol, so don't worry about that. Once I go over it with you it'll all make sense.
For the wb you need a entire wb system. This will include a dash mounted gauge, (or where ever you want it) it's a must to see what is going on while you tune. It will get wired to the ecu using the driver side o2 wiring. The stock o2 harness can be removed. (Unless you are using something else in it).
Join us here for the MS discussion and we have links posted so you can download the base version of the software for FREE! This way you can brows thru the program and see if you feel comfortable with it.
http://www.stangnet.com/mustang-forums/threads/the-megasquirt-tunerstudio-help-thread.888730/
Jrodstang87
41
Mar 11, 2016
#44
  • Mar 11, 2016
  • #44
Seems pretty cool, but how much else will I need to buy other Than the kit and wide band system. And what wideband would work well with that system
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Mar 11, 2016
#45
  • Mar 11, 2016
  • #45
You will need a soldering iron and solder, I suggest the lead solder. And some misc stuff like heat shrink.
Any wb will work I suggest the mtxl it's what I use but as long as it has an output to wire into the ms your gtg. Plx wb are also good.
Jrodstang87
41
Mar 11, 2016
#46
  • Mar 11, 2016
  • #46
Oh good, as long as I would need more modules or anything bank breaking haha. I will definitely read more into it. Sounds exciting!!
Jrodstang87
41
Mar 12, 2016
#47
  • Mar 12, 2016
  • #47
So tuning options aside. Whether I got maf or pnpdiy. Do you think the systemax us a good option for tfs 170 heads and a custom cam? Not too big of an intake?
stykthyn
5,232
2,652
223
gainesville
Mar 12, 2016
#48
  • Mar 12, 2016
  • #48
Imho it's a great intake that even if it's little too much for your current application will run well and offer room for more growth down the line.
Reactions: A5literMan
Jrodstang87
41
Mar 12, 2016
#49
  • Mar 12, 2016
  • #49
Awesome, just picked up some 30# injectors, just have a few things left to find. Then get that cam ground!
stykthyn
5,232
2,652
223
gainesville
Mar 12, 2016
#50
  • Mar 12, 2016
  • #50
Be honest with yourself and the grinder about future plans/goals for the car. It will make all the difference between an OK motor and omg this thing made me crap my pants.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 12, 2016
#51
  • Mar 12, 2016
  • #51
i've got a PRO M bullet 75MM MAF calibrated for 30# injectors for sale. PM me if interested.
Jrodstang87
41
Mar 12, 2016
#52
  • Mar 12, 2016
  • #52
Awesome. I guess it's possible for forced induction in the future but that would be waaaay distant future. So should I just get one ground for staying NA?
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Mar 12, 2016
#53
  • Mar 12, 2016
  • #53
If staying n/a for awhile then get it ground for that. My cam was done by bullet cams but it was Spec'd by a member of a different forum. He has done a lot of cams. I still have his info if you're interested. A billet core runs around 400$ to your door. FYI. Mine was Spec'd around tfs 205cc 11r heads,HolleySMII,30#inj,LT headers,manual trans,3.73 gears. It had 223/227*dur at .050 w/ .525/.525 lift. Was going to pull to around 6-6200rpm. Also most n/a cams can be run with a blower. It wouldn't be a "perfect" cam but it would run fine. Also if you're going with the PnP don't worry about buying a MAF.
Jrodstang87
41
Mar 12, 2016
#54
  • Mar 12, 2016
  • #54
Great. I was planning on going with FTI, heard great things. Unlesa aomeone recommends someone else for various reasons. I have basically the same mods as you except smaller heads. What did your car make for power, or run in the 1/4?
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Mar 12, 2016
#55
  • Mar 12, 2016
  • #55
Unfortunately I had to scrap the project and in the process of selling the car soon. Didn't get it running. Dyno tuner and cam guy predicted around 350rwhp and 11sec et's. With your combo of parts and a custom cam, you should expect around 300-330rwhp.
Jrodstang87
41
Mar 12, 2016
#56
  • Mar 12, 2016
  • #56
Ohh that's too bad. Bummer. Part of me feels like the systemax will be too big for my setup, wondering if I should go with the street heat trick flow. Idk. Plus i would have to put my stock valve covers back on, cause I read the systemax doesn't work with tall fms Covers. I will have to make my stockers clear the 1.7rr. No big deal if the intake Is the right choice. I'm just worried that it is too big
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Mar 12, 2016
#57
  • Mar 12, 2016
  • #57
It's not to big bud. It's perfect for a h/c/i 302/306.
Jrodstang87
41
Mar 12, 2016
#58
  • Mar 12, 2016
  • #58
Perfect. Then looks like I have to hunt for systemax, 70mm TB and think a 75mm maf is sufficient?
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Mar 12, 2016
#59
  • Mar 12, 2016
  • #59
I'd go 75mm tb also but the 70 work fine. The reason I say 75mm tb is for a few reasons. For one there is no down side of having everything in front of the intake(tb,cai,MAF) being as big as possible. You want as much airflow capabilities as possible. It doesn't effect anything in a negative way. The Holley intake is a 75mm opening(actually it's about 73.5 lol) and you don't want any choke points. If you do add a blower or whatever you'll want a 75 at a minimum anyway. So buy once! Also I highly recommend Accufab for the brand. BBK has a tendency to whistle and are t as good. FTI is a good choice for your cam. Ed does a great job. You probably will have to buy springs for the heads/cam change just FYI. My Holley cleared some canton valve covers. Not sure on FMS brand but the tall covers are for a carb setup are t they?
stykthyn
5,232
2,652
223
gainesville
Mar 12, 2016
#60
  • Mar 12, 2016
  • #60
Explorer covers clear tall rockers but the systemax sits low and has a hard time clearing stock valve covers.
  • 3
  • 4
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
9K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
