whats up
here is some stuff i have saved cause smog is a bitch, i had a real tough time smoggin my ride cause i got a good cam in that car, i ended up just loosening the cat back from the h pipe but they have a sensor to see that there are no large exhaust leaks so you got to play with the gap till the numbers are good, go to a no pass no pay place and its no prob. you can also let the car get pretty hot by holding the rpm;s up while it is not moving, not a pretty thing to watch or see but my uncle owns a smog shop and ive seen him pass some garbage by getting it real hot. you can try opening up the spark plug gap a bit also, try putting some dialectical grease on the connections to make sure good spark also.
good luck bro
Back timing down to 8 degrees
(any less is not legal)
Run hotter T-stat (192)
Full tune up w/oil change
Adjust idle to as close to 1000rpm
without going over (950 is the best)
Have fuel inj professionally cleaned or use
the below mentioned (Amzoil Power Foam)
Spray 1 full can of Amzoil's Power Foam in the
throttle body while car is running
Double check to make sure your TPS is at
.993-.995
Back fuel pressure down (around 30psi w/vacuum)
if you got and adjustabel fpr
Run 2 oz of "RXP". Many mechanics at smog s
tations use this to pass customer cars.
this **** is real good
Use 89 octane, higher octane burns slower and
raises emmissons
Run 1 or 2 bottles of rubbing alcohol to a
1/4 tank of 89 octane
If you are still having problems, you can goose it. Depends on how much
they check.
For the test
1. Disconnect the check engine lightbulb
2. Run the smogpump tube directly to crossover behind the heads.
3. Run a hose from the h-pipe/4cat air injection tube in a sneaky fasion
and dump it to the fender.
You are now adding more air earlier and dumping some exhaust.
4. Do the same with the hose on the side of the filler neck. Crankcase
vapors are now being dumped.
If this still fails, get an alternator pulley and attach it to the smogpump front. You will need to drill 3 holes in the inner crevase of the pulley to get it to attach. DONT DRIVE LIKE THIS! Attach the pulley around the corner from the shop and dont idle there while waiting. The airpump _will_ sieze after 15 minutes of this but until then, it will be a supercharger for your exhuast. There will be practically fresh air bellowing out of your tailpipes.
