california emissions
  • Thread starter Thread starter llewellur
  • Start date Start date Aug 26, 2009
L
llewellur
carrollton, IL
Aug 26, 2009
  • Aug 26, 2009
So, I got a job in California and I know my 87 5.0 isn't going to pass emissions... I'm not sure what i'm going to have to do to make it pass though. I'm sure i'll have to replace the exhaust due to the fact that it has no cat and so on...But is there a certain type of muffler and jungk that I have to use? and what all should I look over closely to make sure that It'll pass? I'd like to know everything that i'll need ( or atleast close to it) like, should i look and make sure that all my vaccum lines are routed where they need to be and not plugged up by foriegn objects, is there a certain smog pump that i'll be needing, are there any regulations on fuel pressure regulators, do I to switch over to MAF, and so on? The motor is stock except for a K&N filter...I would just like to know what i'll be needing so i can get a rough estimate of how much this'll cost me.
thanks,
Llew.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 27, 2009
  • Aug 27, 2009
welcome to Kommiefornia that car is gonna need EVERYTHING that came from the factory regarding smog equipment especially since it came from another state
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 27, 2009
  • Aug 27, 2009
Keep it registered from the state you came from if you can
1991vert
1,103
Ludlow, MA
Aug 27, 2009
  • Aug 27, 2009
haha good advice
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 27, 2009
  • Aug 27, 2009
no seriously, keep it registered their and you wont have to pay a whole butt load of fees, Kommiefornia just double the registration fee, cant wait to register my truck this year for the total deal of $500
1991vert
1,103
Ludlow, MA
Aug 27, 2009
  • Aug 27, 2009
maybe soon CA will break off into the ocean and become an island and u wont have to worry about it
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 27, 2009
  • Aug 27, 2009
then how am i gonna get to the free states
Wicked65
490
NORCAL
Aug 27, 2009
  • Aug 27, 2009
Find a job somewhere else.. Its going to hell here..
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Aug 27, 2009
  • Aug 27, 2009
i'll wait till i get my badge here then transfer elseware
87GT40
59
virginia
Aug 27, 2009
#10
  • Aug 27, 2009
  • #10
i agree keep it registered out of state. i had to do that because of stupid connecticut. dumb new englanders.
1990blowngt
#11
  • Aug 28, 2009
  • #11
There are also "special" smog shops in CA that will make it happen.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 28, 2009
#12
  • Aug 28, 2009
  • #12
How to pass emissions testing:
High NO - high combustion temps - retard timing, check EGR for operation.
High CO – Rich condition - fuel pressure too high, check O2 sensors, replace air filter, Clean MAF element.
High HC – Lean misfire, vacuum leak, common misfire due to worn or weak ignition system components. On rare occasions, an overly rich mixture may be the cause. Do the ethanol/E85 fill up as suggested.
High CO & HC - Cat converters, smog pump, and smog pump controls.
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats. The smog tech will do a visual check to make sure that all the original equipment is present and connected up.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
Some basic theory to clarify how things work is in order…
EGR System theory and testing
The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops
combustion temperature, increases gas mileage and reduces the tendency of the engine to ping. It can also reduce HC emissions
by reducing fuel consumption. The primary result of EGR usage is a reduction in NOx emissions.
The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum
regulator. The EVR is located on the back of the passenger side shock strut tower. The computer uses RPM, Load. and some other
factors to tell the EVR to pass vacuum to open the EGR valve. The EGR valve and the passages in the heads and intake manifold
route exhaust gas to the EGR spacer (throttle body spacer). The EGR sensor tells the computer how far the EGR valve is open.
Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to
compensate for the recirculated gases and the slower rate they burn at.
Troubleshooting:
There should be no vacuum at the EGR valve when at idle. If there is, the EVR (electronic vacuum regulator) mounted on the
backside of the passenger side wheelwell is suspect. Check the vacuum line plumbing to make sure the previous owner didn’t
cross the vacuum lines.
Diagram courtesy of Tmoss & Stang&2birds. (the diagram says 88 GT, but the EGR part is the same for 86-93 Mustangs)
The EGR sensor is basically a variable resistor, like the volume control on a radio. One end is 5 volt VREF power from the
computer (red/orange wire). One end is computer signal ground (black/white), and the middle wire (brown/lt green) is the signal
output from the EGR sensor. It is designed to always have some small voltage output from it anytime the ignition switch is the
Run position. That way the computer knows the sensor & the wiring is OK. No voltage on computer pin 27 (brown/lt green wire)
and the computer thinks the sensor is bad or the wire is broken and sets code 31. The voltage output can range from approximately
.6-.85 volt.
The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70
Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is
regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the
run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches
the ground on and off to control the regulator solenoid.
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connnect the test jig or to directly to manifold vacuum.
Do not connect the EGR test jig to the EVR (Electronic Vacuum Regulator).
apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
Use your finger to cap the open port on the vacuum tee.
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 2-5 in vacuum?
if not the EVR has failed
EGR test jig
To test the computer, you can use a test light across the EVR wiring connectors and dump the codes. When you dump the codes,
the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker.
Late Model Restoration has the Ford Racing M-12071-N302 kit with the EGR valve & sensor along with the ACT & ECT sensors for
$45. See http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M12071N302 1&comp=LRS for
more details
Thermactor Air System
Some review of how it works...
The Thermactor air pump (smog pump) supplies air to the heads or catalytic converters. This air helps break down the excess HC (hydrocarbons) and CO (carbon monoxide). The air supplied to the catalytic converters helps create the catalytic reaction that changes the HC & CO into CO2 and water vapor. Catalytic converters on 5.0 Mustangs are designed to use the extra air provided by the smog pump. Without the extra air, the catalytic converters will clog and fail.
The Thermactor air pump draws air from an inlet filter in the front of the pump. The smog pump puts air into the heads when the engine is cold and then into the catalytic converters when it is warm. The Thermactor control valves serve to direct the flow. The first valve, TAB (Thermactor Air Bypass) or AM1 valve) either dumps air to the atmosphere or passes it on to the second valve. The second valve, TAD (Thermactor Air Diverter valve or AM2 valve) directs it to the heads or the catalytic converters. Check valves located after the TAB & TAD solenoids prevent hot exhaust gases from damaging the control valves or pump in case of a backfire. The air serves to help consume any unburned hydrocarbons by supplying extra oxygen to the catalytic process. The computer tells the Thermactor Air System to open the Bypass valve at WOT (wide open throttle) minimizing engine drag. This dumps the pump's output to the atmosphere, and reduces the parasitic drag caused by the smog pump to about 2-4 HP at WOT. The Bypass valve also opens during deceleration to reduce or prevent backfires.
The computer uses the change in the O2 sensor readings to detect operation of the Thermactor control valves. When the dump valve opens, it reduces the O2 readings in the exhaust system. Then it closes the dump valve and the O2 readings increase. By toggling the dump valve (TAB) and switching the diverter valve (TAD) flow from the back of the heads to the air pipe, the computer tests for the 44/94 codes.
Computer operation & control for the Thermactor Air System
Automobile computers use current sink technology. They do not source power to any relay, solenoid or actuator like the IAC, fuel pump relay, or fuel injectors. Instead the computer provides a ground path for the positive battery voltage to get back to the battery negative terminal. That flow of power from positive to negative is what provides the energy to make the IAC, fuel pump relay, or fuel injectors work. No ground provided by the computer, then the actuators and relays don't operate.
One side of the any relay/actuator/solenoid in the engine compartment will be connected to a red wire that has 12-14 volts anytime the ignition switch is in the run position. The other side will have 12-14 volts when the relay/actuator/solenoid isn't turned on. Once the computer turns on the clamp side, the voltage on the computer side of the wire will drop down to 1 volt or less.
In order to test the TAD/TAB solenoids, you need to ground the white/red wire on the TAB solenoid or the light green/black wire on the TAD solenoid.
For 94-95 cars: the colors are different. The White/Red wire (TAB control) is White/Orange (Pin 31 on the PCM). The Green/Black wire (TAD control) should be Brown (pin 34 at the PCM). Thanks to HISSIN50 for this tip.
To test the computer, you can use a test light across the TAB or TAD wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker.
Theory of operation:
Catalytic converters consist of two different types of catalysts: Reduction and Oxidation.
The Reduction catalyst is the first converter in a 5.0 Mustang, and the Oxidation converter is the second converter. The Oxidation converter uses the extra air from the smog pump to burn the excess HC. Aftermarket converters that use the smog pump often combine both types of catalysts in one housing.
Now for the Chemistry...
"The reduction catalyst is the first stage of the catalytic converter. It uses platinum and rhodium to help reduce the NOx emissions. When an NO or NO2 molecule contacts the catalyst, the catalyst rips the nitrogen atom out of the molecule and holds on to it, freeing the oxygen in the form of O2. The nitrogen atoms bond with other nitrogen atoms that are also stuck to the catalyst, forming N2. For example:
2NO => N2 + O2 or 2NO2 => N2 + 2O2
The oxidation catalyst is the second stage of the catalytic converter. It reduces the unburned hydrocarbons and carbon monoxide by burning (oxidizing) them over a platinum and palladium catalyst. This catalyst aids the reaction of the CO and hydrocarbons with the remaining oxygen in the exhaust gas. For example:
2CO + O2 => 2CO2
There are two main types of structures used in catalytic converters -- honeycomb and ceramic beads. Most cars today use a honeycomb structure." Quote courtesy of How Stuff Works (HowStuffWorks "Catalysts")
What happens when there is no extra air from the smog pump...
As engines age, the quality of tune decreases and wear causes them to burn oil. We have all seem cars that go down the road puffing blue or black smoke from the tailpipe. Oil consumption and poor tune increase the amount of HC the oxidation catalyst has to deal with. The excess HC that the converters cannot oxidize due to lack of extra air becomes a crusty coating inside the honeycomb structure. This effectively reduces the size of the honeycomb passageways and builds up thicker over time and mileage. Continuous usage under such conditions will cause the converter to fail and clog. The extra air provided by the Thermactor Air System (smog pump) is essential for the oxidation process. It oxidizes the added HC from oil consumption and poor tune and keeps the HC levels within acceptable limits.
Newer catalytic converters do not use the Thermactor Air System (smog pump) because they are designed to work with an improved computer system that runs leaner and cleaner
They add an extra set of O2 sensors after the catalytic converters to monitor the oxygen and HC levels. Using this additional information, the improved computer system adjusts the air/fuel mixture for cleaner combustion and reduced emissions. If the computer cannot compensate for the added load of emissions due to wear and poor tune, the catalytic converters will eventually fail and clog. The periodic checks (smog inspections) are supposed to help owners keep track of problems and get them repaired.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
It's about $25-$35 from Borders.com see Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more . Select books and then select search. Use the ISBN number (without dashes or spaces) to do a search
Use the ISBN number and your local library can get you a loaner copy for free. Only thing is you are limited to keeping the book for two weeks. It is very good, and I found it to be very helpful.
If you need some help with your automotive electrical skills, try Automotive Online Instruction for a beginning course. The course is very good and best of all, it is FREE!!!
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 28, 2009
#13
  • Aug 28, 2009
  • #13
MA is actually pretty good. No more emmissions testing for Pre-1995 cars. SO when i inspected my 5.0, i have ZERO smog equipment hooked up other than having the 4 cats on the car and passed
Bout damn time we got a break here.
mc0311grunt
86
Los Angeles
Aug 29, 2009
#14
  • Aug 29, 2009
  • #14
as long as you have the cats, All OEM smog pump stuff, and C.A.R.B aftermarket perts you'll be ok. I passed with no mufflers but good Idea to get a set. Also they pressure test the fuel system and the gas cap in this state. Crappy California
L
llewellur
carrollton, IL
Aug 30, 2009
#15
  • Aug 30, 2009
  • #15
so, lets say that I "gift" the car to my dad and transfer the title and license to his name...I suppose that would be much easier?
87GT40
59
virginia
Aug 31, 2009
#16
  • Aug 31, 2009
  • #16
not than that keeping it registered in your name and your home state. then nothing changes when it comes time to re-register.
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
C
Exhaust 4 Cats required for smog in California?
  • Codosuarus
  • Sep 28, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
Scottyding73
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
