Cam Choice...
  • Thread starter Thread starter Adam95GT
  • Start date Start date Mar 7, 2007
Adam95GT
2,564
Burlington, NJ
Mar 7, 2007
  • Mar 7, 2007
Well im going to be getting my gt40p motor ... and i need help picking out a cam... ive been told e303.... and b303.... i found a f303 for cheap... what is the most streetable cam with decent torque curve
Adam95GT
2,564
Burlington, NJ
Mar 7, 2007
  • Mar 7, 2007
anyone.... i wanna run with stock ecu no tune .... whats the best fo me!
94CobraPace
907
Houston, Tx.
Mar 7, 2007
  • Mar 7, 2007
The E cam is susposed to be good with the 94\95 computers & has good mid range power, but falls a little short on the upper end, good tq.. Stay away from the B cam. Not sure on the F?
JJ95GTID
1,141
Phoenix, AZ
Mar 8, 2007
  • Mar 8, 2007
It seems to be the consensus that no matter what cam you put in there you run the risk of needing to tune.
I have found a few running the F cam without tuning probably due to its 114*lsa. Its weak point is no low end and power doesn't come on untill around 3000rpms.
The Steeda #19 is supposed to made for out 94-95 Mustangs and yet some still need tuning and some don't. It also seems to have soft lower rpm.
Maybe just try running 1.7:1 roller rockers with the stock cam and see if you like it. At least you'll know you don't need a tune and it does have great low end.
ProKiller
3,064
15
78
PA
Mar 8, 2007
  • Mar 8, 2007
e-cam of fury eh? tuning is where the power is, don't wuss out on the tune, your spending how much to get the engine swapped and parts and you can't afford a tune?
Black95GTS
1,644
Marlborough, MA
Mar 8, 2007
  • Mar 8, 2007
You want a wide LSA cam that pulls good vacuum. Neither the E cam nor the B cam have this. Some of these problems can be fixed by adding fuel pressure and twisting the distributor, but I feel that these tuning methods are bush league when dealing with fuel injection.
The F cam is a good forced induction camshaft, and does pull good vacuum with a wider LSA. It will most likely be your friendliest alphabet cam.
The e-cam gained a lot of popularity in Fox mustangs, because it does prove a decent pickup over stock, using their computer. Ours are different.
Save up and buy a custom cam. Until then, buy some 1.7s and retard timing 4 degrees. Your custom grinder will take your 1.7s into account so the money won't be wasted.
Adam
Black95GTS
1,644
Marlborough, MA
Mar 8, 2007
  • Mar 8, 2007
Exactly. You wouldn't drop a new carb on your car without tuning it, so why do peeps think you can drop new parts onto an FI car and not tune it?
The key to a great combo is that everything has to work together. The tune is the glue that keeps everything working as one.
Adam
Adam95GT
2,564
Burlington, NJ
Mar 8, 2007
  • Mar 8, 2007
im only dropping about $1700... and tuning around here is expensive as ****...
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 8, 2007
  • Mar 8, 2007
im happy with my 2031
BlackVert
5,589
9
98
Bethesda, MD
Mar 8, 2007
#10
  • Mar 8, 2007
  • #10
is anyone running the tfs stage 1 cam without needing a new tune?
do 1.7 rockers fit under our stock valve covers?
droptopford 5 0
427
Mar 9, 2007
#11
  • Mar 9, 2007
  • #11
on a side note does the tfs stage 1 cam pull enough vacuum ??
blksn955.o
3,263
st.louis mo 314
Mar 9, 2007
#12
  • Mar 9, 2007
  • #12
I did a good amount of research on gt40 heads and what numbers they like cam wise.
The gt40's will like a split patt. that fav. the exh. side (ie. NO letter cams). For the intake the number was around .490-.500 and .500-.510 for exh. with a dur. that favors the exh. side around 3-5.
I went with the TFS 1 cam on my unported gt40's, the numbers are alittle on the high side of what gt40 heads like but not too bad to make it over-cammed. I ran the cam 100% un-tuned for awhile. I had a bucking at part throt (found that to be a C&L maf issue though), cold start was rich and would stall, every blue moon it would stall after warm up after a quick slow down to a stop. I could catch it every time on the slow down to a stop and it only died like 3-4 times in a few years. Ran GREAT for the combo I thought...I really wish the shortblock didnt crap out on me to run it more.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 9:11 AM
smittys7up
