I have a 302 with trick flow 170 twisted wedge heads track heat intake 4.10 gears 70 mm tab and 75 mm maf with 24 lb injectors. I have an f303 and a n61 Anderson cam. Which one would work best?
I'd like to say that I've heard many more good things about the Anderson cams than the F cam. The FRPP letter cams are really old camshaft designs and there's plenty of better cams out there.
N61 hands down but it may be tight you'll have to check clearance. Off top of my head that can is .544/.568 228/232 110. You'll need to rev it to make power 4:30s would be better.
