I just pulled my engine because of a siezed oil pump and a broked pump driveshaft. Ive decided to build a 347 stroker using a CHP kit, AFR 185 heads, a Performer intake (I already have it and can upgrade later), but cant decide on a cam. It has to pass California emissions so everything needs a CARB#. I know the 347 is not emissions legal, but they wont know. I was looking at the Crane #444221 or #444225. The 444221 has a lift of 533 int. and 544 exh. with a duration of 216 int. and 220 exh. The 444225 has a lift of 513 int. and 529 exh. and a duration of 214 int. 220 exh. Will either of these cams work well? Could you recommend other cams that have a CARB#? I will be putting this engine in my daily driver and will road race it a few times a year and some drag.
Thanks,
Clay
Thanks,
Clay
