  • SN95 4.6L Mustang Tech
cam install?
  • Thread starter Thread starter 98laseredgt
  • Start date Start date Dec 15, 2004
9
98laseredgt
122
indianapolis
Dec 15, 2004
  • Dec 15, 2004
ok, so i read over the install in one of my mustang mags. they did a set of comp cams and springs. im wondering how hard it is. they said it took 10 hours or something. but i have seen people saying they have done it in 5 hours or less. im thinking about getting the VT stage 1 cams and possibly doing springs. my car has 79k miles on it so im not sure about their strength. my main issue about the install is timing and the timing chains. do the chains need to be replaced or can you reuse them. and how easy is it to mess it up. bottom line is im not comfortable doing it myself, and i dont want to pay someone 500-600 bucks to put them in. with more info on the subject i think me and some friends could handle it. how much are some of you guys paying for a dyno tune and would that also be needed after the install. anything else you guys can think of that would help would be great. thanks.
nate
f150dan
14
TN
Dec 15, 2004
  • Dec 15, 2004
I am wandering the same thing. I am planning on installing a set of comp stage 2 cams and springs. I guess while I'm in there I might as well replace the timing chain too. I can't wait to hear some answers on this subject though.
JonJon
4,801
back in Marylands
Dec 15, 2004
  • Dec 15, 2004
From what I've read on MD, it's $1000+ for cams/springs install for ONLY labor.
Here's Bill Putnam's writeup, see if you think it's doable...
http://www.modulardepot.com/?show=articlesdet&aid=39
nickthegenius
1,631
Elwood, IN
Dec 15, 2004
  • Dec 15, 2004
The job is not that hard if you have the right tools, just time consuming. There are a couple specific tools that will save you a lot of headaches.
You can try the AFM chain tool to keep from having to pull the front cover. Also, you really need the OTC valve spring tool to do the springs.
Overall, my cam/spring install took about 8.5 hours. Most of the time was spent on the springs. The cams are a breeze with the AFM tool, but you will use words you never use when doing your first bank of springs. Once you do one side though, you learn all the tricks and the other head will go quickly. The only other thing that is a pain is getting the driver's side valve cover back on.
Take a look at Bill Putnam's article that JonJon posted. Even if you pull the front cover, it just adds time and not difficulty.
U
UNVMATT
294
COLUMBUS
Dec 15, 2004
  • Dec 15, 2004
I got quoted 800 for a cam and head swap together
9
98laseredgt
122
indianapolis
Dec 16, 2004
  • Dec 16, 2004
would you guys recommend doing springs with the cams even if its not required. like with the VT stage 1 cams i heard you dont have to replace the springs.
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
