i installed a comp cam xe270hr-12 over the weekend. i installed it straight up. if the cam is automaticly advanced 6 degrees. when i put my distributor back in will 0 on my balancer be top dead center or 6
0 will still be tdc (Assuming that the balancer is right). The cam being ground with 6 degrees built in it has nothing to do with where the piston is at tdc. Hope this helps
