Cam Timing Question
  • Thread starter Thread starter jjones9620
  • Start date Start date Jun 14, 2017
J
jjones9620
  • Jun 14, 2017
Hello,
I have a question about using a degree wheel. I followed all the steps to degree the cam in my 1994 Ford 347 stroker and the intake valve is opening when the cam card says it should (3.0 BTDC) but its closing at a totally wrong number (I think it was 150 degrees instead of 38 ABDC) The exhaust valve is closing right when it should ( 4.0 BTDC) but is opening at a totally wrong number (130 instead of 49 BBDC). I am not sure what to do. Intake opens when it should, exhaust closes when it should, do I need to figure out why the other numbers are wrong? I already checked the part numbers and they are correct.
J
jjones9620
  • Jun 16, 2017
I solved this mystery. Turns out you have to subtract 180 degrees from the number I was getting. The 180 mark represents bottom dead center.
D
Engine Checking valve events with degree wheel.
  • dragstart
  • Jun 1, 2024
Fox 5.0 Mustang Tech Jun 1, 2024
dragstart
D
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
