Cam to lifters to heads relations
black50
36
I've been reading alot about building shortblocks, theres some information pertaining to picking the right cam, but no information on how hydraulic roller cams shafts work in relationships to the lifters, hoping to get alot of feedback on these questions, motor runs on a four stroke combustion cycle, for every two revolutions from the crank shaft it turns the cam shaft 360 degree's. now when the cam is turning how does it work in relationship with the lifters to pushrods to valves in the heads? are the lobes in the cam shafting rotating and pushing the lifters up, pushing the pushrods up rising the rocker arm and opening the valve in the head? its one thing to know alot about mustang and aftermarket parts its another thing doing the work yourself! I like doing the work myself:stupid:
are the lobes in the cam shafting rotating and pushing the lifters up, pushing the pushrods up rising the rocker arm and opening the valve in the head?:
Basically yes, the timing chain connects the rotation of the cam and crank together, as the lobes of the cam rotate, the lifters which ride on the cam go up or down pushing on the pushrods which open and close the valves via the rockers. Picking the right cam depends on the exact head and intake you have, you can play with the valve timing to make them work better together. The spark plug/ignition fires based on the cam timing (the lobes are made to opena dn close certain cylinders in a particular orde) dist etc..it all works together to create power.
The 5 round journals are where the cam rests inside the cam bearings, the other shapes are more pear like and these are the lobes int/exh that the lifters ride on, the gear meshes with the dist gear...
Rick seems to cover you quite well:nice:
Yeah, the crank rotates twice for every one rotation of the camshaft.
So if you are revving to 6,000 rpm, your camshaft is at 3,000 rpm. Makes you wonder why you need billet camshafts for street cars:shrug:
There are 4 strokes to these engines:
- Power stroke
- Exhaust stroke
- Intake stroke
- Compression stroke
If you would like to read more about it, check out the camshaft valve timing link in my signature. I hope it makes sense to you. It is after the terms dictionary at the beginning.
