  • 1994 - 1995 Specific Tech
cam upgrade
  • Thread starter Thread starter yzfr12007
  • Start date Start date Sep 15, 2010
Y
yzfr12007
Illinois
Sep 15, 2010
  • Sep 15, 2010
i have a stock set of heads and looking at an x303 cam do i need to upgrade my rockers or anything else that i have to change to run that cam???
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 15, 2010
  • Sep 15, 2010
You need to upgrade your heads. That cam will tear your engine to pieces.
Kurt
ProKiller
3,064
15
78
PA
Sep 16, 2010
  • Sep 16, 2010
its a little too aggressive for stock heads. you'd be better off getting better heads than a cam swap at this point.
skeptiq
26
Cincinnati
Sep 16, 2010
  • Sep 16, 2010
Not to hijack this, but for stock heads, what cam would work without killing the engine?
B, E, F???
Thanks,
Ben
alleymad95GT
204
Okemos, Michigan
Sep 16, 2010
  • Sep 16, 2010
For stock heads, you are better served just going with some 1.7 roller rockers.
That's just my opinion...
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 16, 2010
  • Sep 16, 2010
While I don't care for alphabet cams
One thing to keep in mind is .........
those cams were built to crutch up the piss poor e ports of OEM heads
therefore
It would seem to me that ...........
e cam would be more suited to be used with E7's than a TFS 1 cam that
was built for heads that do not have the same short comming as
old OEM iron heads
Just a thought
Grady
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 16, 2010
  • Sep 16, 2010
There old single grind cams. They were designed to give old SBFs that classic grumbling noise. I'd also like to add that a .542 lift cam is likely to have piston to valve clearance issues without notching the pistons.
Kurt
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 17, 2010
  • Sep 17, 2010
Agree. If you have poor-flowing heads there's no point in having a big cam. Actually you could transplant higher-flowing heads onto the 5.0 and it would perform very well with the stock cam and 1.7 RRs.
BlackVert
5,589
9
98
Bethesda, MD
Sep 17, 2010
  • Sep 17, 2010
your best upgrade would be getting a new intake and swapping out the gears before doing a cam. do the cam and heads together
just a couple of pennies from an old fart
skeptiq
26
Cincinnati
Sep 17, 2010
#10
  • Sep 17, 2010
  • #10
Thanks for the info... was curious myself. I had been kicking around the idea of e303 for my E7's, but I think I am just going to leave the vert alone in that dept. If anything I do like the idea of the 1.7's. Would the rockers upgrade be noticable in terms of hp gain, or minimal?
My current setup:
3.73's
Cobra upper / .5" spacer / lower
70mm TB
Cold air
Shorty headers
Pro Chamber
Pro Dumps
Thanks,
Ben
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 17, 2010
#11
  • Sep 17, 2010
  • #11
IMHO ... 1.7 rr's would gain less than 10 rwhp
Grady
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 17, 2010
#12
  • Sep 17, 2010
  • #12
10 rwhp isn't bad considering it's a 1 hour swap, and the rockers are something you're going to need eventually anyway. A cat back is only like 10rwhp, and that takes half a day to install, and costs twice as much.
Kurt
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 17, 2010
#13
  • Sep 17, 2010
  • #13
I'd bet you'd be closer to 5 than 10
Grady
Black95GTS
1,644
Marlborough, MA
Sep 18, 2010
#14
  • Sep 18, 2010
  • #14
"The best cam for stock heads is the stock cam." - Jay Allen
Adam
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 18, 2010
#15
  • Sep 18, 2010
  • #15
The gain is more like 5rwhp but 1.7 rockers are still worth it. They're easy to install and you can still use them if you upgrade to better pedestal-mount heads and upgrade the cam later on.
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
