Cam with stock heads?
if you just want a noise maker pick any cam you want. The f-cam sounds like a monster, but you will have hondas passing you left and right.
its usually a good idea to change the springs for a fresh set. if you are keeping the stock cam then go with stock springs. Aftermarket cam, get a spring set rated for the amount of lift you are looking at.
The stock cam is actually not as bad as people make it out to be.
The heads are what sucks. I've seen GT40/GT40P headed cars into the 12's with the stock cam.
It's all about making parts work together.
