CAMBER PATE QUESTION
  • Thread starter Thread starter jaidedeye
  • Start date Start date Oct 22, 2004
jaidedeye
627
Goldsboro nc
Oct 22, 2004
  • Oct 22, 2004
well i put my springs on my car and it dropped it almost 2 inches...well i need to install my bbk camber plates....do i need to remove the front shocks to take the old stuff on and put the new stuff on?
whats rediculous is that nobody around here will do an alighnment on a lowered car.... so i went to carcraft.com and downloaded thier instructions on how to do it at home....
J
jerry beach
2,671
Ocala,FL
Oct 22, 2004
  • Oct 22, 2004
Do you have the instructions? You dont really have to remove them, but it may be easier that way. You wont have to fight the pressure or the strut to bolt down the plates that way. In any case you will have to take the top nut loose. Sometimes its best to use an impact wrench for this. I was replacing my worn out ones at the same time, so I used vice grips to keep the strut shaft from turning.
Dont align the front end yourself. You may get the toe and camber close, but you wont get the camber right at all. Dont tell them the car is lowered. Just keep checking around, you will find someone to do it. I wont give anyone the keys anymore. I tell them that I will drive it on and off the rack and do the test driving or they wont work on my car. Alot of shops will tell you to get lost when you tell them that, and I found a shop to do mine.
I also recommend flat washers above and below the plates, in addition to washers on top of the strut tower. I have to take mine back apart to do this. For good installation instructions go to www. maximummotorsports.com, click on instructions and choose the CC plates. The install is the same in general for all brands. Or try the bbk site for instructions. Have fun.
1990LXDropTop
430
Western Massachusetts
Oct 22, 2004
  • Oct 22, 2004
Hmmm thats weird that no one will do an alignment on your car. I recently lowered my car 1.5", and when I went to get it aligned, they coudn't drive it up onto the lift because the h-pipe hangs too low. I ended up going to this place that specializes in alignments, and they did an alignment no problem.
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Oct 22, 2004
  • Oct 22, 2004
Just for reference. We have strust in the front and shocks in the rear.
jaidedeye
627
Goldsboro nc
Oct 22, 2004
  • Oct 22, 2004
yeah i knew that.....
well the thing is that i gotta get my alignment /camber at least close. i have new tires on my car.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
