can you run vt stage 2 n/a cams on with stock ports on your heads? I know you need springs gears, converter, and computer upgrade just not sure if you need a p&p job on the heads or if you can put that off for now.
you dont need it, but the stage II cams really shine with a P&P job. thats when they start to perform better than the stage I's. If you're planning on definetly doing the P&P, get the stage IIs.
I agree. On my HP curve it tops out around 5500 and levels off until around 6200 where it drops off. If I was P&P'd I think it would've kept going up until 6200.
