Can I use a dented H pipe?
The rubber hangers on mine disintegrated a long time ago. That is what those hooks are for. You can use some backyard engineering and wire it up but I've found it doesn't hurt anything. You can reuse the old bolts and stud but replacements can be found at Napa. Do yourself a favor and invest in some PBBlaster. Spray the hell out of the nuts (the old h-pipe, not yours) and it will be much easier to remove.
How come this H pipe didn't come with the hooks? Is it possible i got one for the wrong car? The guy i bought it from told me he got it off a 03, and i figured that 99-04 share the same H pipe.
Also, why would i need new studs? I won't have to take the old ones out, right? They (the old studd) will stay on the Header, all I remove is the nut, to free the old H pipe, right? The clamps on the side of the H pipe that go to the Header aren't even threaded.
I've already sprayed the crap out the bolts with PB blaster. I outta buy a stock in that thing.
Ah, great.
I should have tools available to me this saturday hopefully. Apparently, Early MAC H pipes like the one I have are extremley prone to leaking. Hopefully all goes well.
Make sure you get a new gasket. Ford has them for about 15 bucks if I remember. If you get a leak just use some high temp RTV and seal it. Pain in the ass if you have to remove it for any reason but it will stop the leak.
What sleeves?
I found the leak, SEAFOAM FTW!
It's On the DRIVER side, i have like a quarter of an inch worth of space between the h pipe and the header. i could of sworn i tightend the crap out of it
