S seijirou Founding Member Aug 15, 2002 2,417 4 48 DFW Nov 23, 2010 #1 Nov 23, 2010 #1 As the title asks, can I use a fox smog pump in a 94? What I'm really looking to know is if it will physically bolt up *and* not give me any belt alignment trouble. Fiddling with the hoses is no problem. Thanks!
94GTCoupe 10 Year Member May 7, 2006 1,412 92 79 CA Nov 23, 2010 #2 Nov 23, 2010 #2 Yes you can. Search threads started by me for the "how to".
S seijirou Founding Member Aug 15, 2002 2,417 4 48 DFW Nov 23, 2010 #3 Nov 23, 2010 #3 davis3 said: Yes you can. Search threads started by me for the "how to". Click to expand... Oustanding. Thank you sir! Just in case someone later comes a long and finds this in searching, here is a link to the thread you mention. http://www.stangnet.com/mustang-forums/783109-how-install-fox-body-smog-pump-lots-pics.html
blksn955.o Founding Member Mar 15, 2002 3,263 0 66 st.louis mo 314 Nov 24, 2010 #4 Nov 24, 2010 #4 I am running a fox smog pump. Just swapped the pulley and my rubber hose/line had enough flex to be hooked up with no issues.
