I was wondering if anyone knows if I would be able to run afr 165 with the flat top pistons that I am currently running?
wealth of knowledge noobzProbably not but you won't know for sure until you clay it up. The TFS heads fit (usually) but there are still some cam limitations.
Soo, best bet and I suppose only option would be to take the car into the speed shop have em tear the top end down and see what heads I can run? The cam is not stock either by the way.
I was unaware that the pistons could still have valve reliefs, thanks. $700 is a bit much I suppose for a set of iorn heads that have been ported, but buying a used set of aluminum's isn't that good of a deal either. Let's say you bought a used set of trickflow's for $700, are you really gonna put them on your car without a trip to the machine shop? I mean you don't really know what you have when you're buying of the net, and by the time they've been planed, and new springs, ect put on you savings are out the window. So when it comes time to buy heads what do you do, take care to shop have them tear the top end off and see what type of aftermarket head will fit and then throw it back together, get on latemodelrestore.com order the heads and then take it back to shop and have them installed? What a headache, pun intended. Should've gotten a topend kit from the get go I suppose. As of now I have rebuilt stock heads, stock valve size w/ 3 angle valve job. Cam specs are 281 281 220 220 .512 .512 110° Those damn flat top pistons I swear...I wouldn't spend $700 bucks on iron heads, probably not even ported GT40's. You can probably find a used set of TFS for $700. I would definetely find out what kwell.
Joe
) and how much free drop you have. so you have to degree and clay it to know. can an aftermarket cam clear flattops? hell yes it can and not just with a twisted wedge. but there is only one way to know yours will.
