can someone decode my VIN?
  • Thread starter Thread starter 1WildII
  • Start date Start date Feb 4, 2004
1WildII
199
Anacortes, Wa
Feb 4, 2004
  • Feb 4, 2004
ok its a 1971 Mustang, but you'll find out if you decode it. I need some info for a school project. Any help would be awsome. the vin is 1FO1L181014. I got all the info off the door decoder already, i just need to know what the vin tells me. espicially the date it was built. I hate to say it I waited till almost the last second and its due on Friday. Thanks in advance for the help.
Chris
1971 Mustang
1976 Cobra II
1976 Mach 1
'68StangGT
617
Haslett, MI
Feb 4, 2004
  • Feb 4, 2004
Chris
1971 Mustang
1976 Cobra II
1976 Mach 1
according to this site:
http://www.themustangexperience.com/vindecode.php
The results for VIN #1FO1L181014
Year Code Your car is a: 1971, denoted by code: 1.
Manufacturing Plant Your car was manufactured in the following plant: Dearborn.
Body Type The data that was entered (O1) does not coincide with the two digit codes for a Mustang. Please double-check the vin and try again.
Engine Type Your Mustang came factory equipped with a L code, 250 ci 1V 6 cyl engine that has 145 horsepower.
Unit Number 181014
65fastback2+2
1,229
Louisville, KY
Feb 4, 2004
  • Feb 4, 2004
Year: 1 1971
Plant: F Dearborn, MI
Body Series: 01 2 Door Hardtop
Engine: L 250 1v I6
Unit: 181014 181014
1WildII
199
Anacortes, Wa
Feb 4, 2004
  • Feb 4, 2004
hmmm.... how do I find out the date my car was made? Do i need the buildsheet... because that is long lost. thanks for the help.
Chris
351pacecar
644
Hudson, Wisconsin
Feb 4, 2004
  • Feb 4, 2004
Youll hafta get a vin report from marti.
Just curious but why bother with a '71 6cyl coupe? thats really the bottom of the barrel and a 71-73 mach1 could be had for like $1,500 driveable with no major rust these days.
stangcountry
  • Feb 5, 2004
Chris
look on the data tag on the door
P
Pbford
21
South-Central TN
Feb 5, 2004
  • Feb 5, 2004
Chris
1971 Mustang
1976 Cobra II
1976 Mach 1
Download StangID here: http://66.4.8.35/mustangs/stangid.html
Install it on a laptop and take it with you anywhere. The easiest way to find the month/year of build is to look on the door data plate. For more info FREE call Ford Customer Service and ask for a "999" report. That will give you the build date and the factory options. Hope this helps.
Paul
D
Need help for my PCM Mach1
  • Danaololo
  • Jul 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 30, 2025
Danaololo
D
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
87-93 Mustang T-top/Sunroof production numbers
  • Mustang5L5
  • Jan 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Mustang5L5
D
Progress Thread 1989 GT Procharged
  • Dreamcar
  • Aug 4, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2025
raynist1
R
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
