Can This Manual Pitman Arm be Greased?
joesgt281
163
Katy, TX
It's on an early 67 manual steering car and I haven't found any replacement for it.
The stud that goes into the center link turns okay but it's original equipment and any grease that was in it in 67 is long gone by now.
Can I drill and tap the little bump on the backside of the stud for a grease zerk like tie-rods are done?
Thanks in advance,
Joe
stanger53 said:
Contact www.rareparts.com.
They rebuild these parts. They can sell you a rebuilt unit or they can rebuild your original part.
Thanks Randy....hey nice "Zardoz" avatar :D
The stud turns nicely so I'm not really interested in rebuilding as much as just improving the original design with a grease fitting. Think that can be done?
Joe
you can drill and tap the cover as you have sugested, but keep in mind where all the shavings are going to end up (murphy's law, you know!) after you are done tapping you can flush out all the old grease and crud with carb cleaner , install the zerk, pump'er up with grease, and be on your way.
Good point chromedog.
I had it suggested to me to go slow and, at the point of breakthru, put some heavy bearing grease on the bit to capture the shavings.
