Car backfired, sputtered, and died...
silverlx50
168
62
38
OK I got a 93 LX. Its a 306 with an S-Trim. MSD ignition with MSD boost retard. I have replaced the computer, fuel pump relay, computer relay, and ignition control module (on the distributor) about 2-3 months ago, they all have about 400 miles on them.
My plugs, wires, cap/rotor are about 2 years old with about 1500 miles on them.
Here is the problem. I was driving the car last weekend, it was running like new for about 1.5 hours. All of a sudden while driving at 50 mph the car lost power and immediately began to backfire loudly. I gave it gas and it just sputtered. When I put it in neutral it continued to idle very rough and would not accelerate in gear. It continued to back fire every time I hit the gas and it was not very responsive so I coasted onto a side street. It continued to idle very rough like to timing was completely fubared and continued to backfire when giving gas. After I let it cool (after being towed) it wouldn't even start, just cranks and cranks.
Fuel pressure was about 35-40 when I trun the key on, I hear the pump priming for a couple seconds, no check engine light came on when it took a dump on me. I checked the plug wires, cap/rotor and they look fine (i was hoping just a burnt wire). I haven't checked the timing again, I wouldn't think it could just jump from perfect to sh!*.
Im not sure where to go from here, does anyone have any suggestions?
Checked that it's nice and tight, I looked at the power wire from the MSD ignition box that runs an in-line fuse and when I opened the fuse cover the plastic part of the fuse was completely melted but the fuse was not blown! Well I'm gonna go pick up a new inline fuse section of wire and try that. The metal female connector for the fuse was completely corroded and charred.
I've got my fingers crossed!
Maybe the chain jumped timing? Distributor drive shaft busted? Does the rotor turn when you crank the car?
Are you running a HV oil pump? Those have a history of being hard on the distributor drive shaft.
