lunaelement
- Mar 27, 2007
- 7
- 0
- 0
CAR WILL NOT START
I just ran into this problem last sunday, here is what I have replaced on mine and in the order that I replaced them. I hope this can help one of you guys out cause my s @#$#$%#$% T ! is running again and I am one happy mutha @#$%$^ !
ok, first of all, the symptoms started when my car had a hard time starting from a cold start. I would turn on somethimes and then it would have a hard time starting. I would unplug the spark plug wire that goes from the coil to the distributor cap and would have to clean it every now and then and the car would start.
1) I replaced the coil > it worked ok but the problem started again after a week or so
2) I replaced the distributor cap and with an MSD cap > same crap
3) I replaced the spark plug wires with ford racing 8mm, wire > no change.
At this piont my car started to make a funky clicking sound when I would hit a bump just right. like sound you get when you unplug a spark plug and set it close to the spark plug to see if you getting fire. I would hit another bump and it would go away. A few days later the car started to turn off on me while I was driving. At first I put the clicking noise that I woud get when I hit a bump just right and it turning off and throught that it could be an exposed wire>
4)I checked all wires but nothing seemed to be exposed
the car started to do this more often > a few times I was able to pop the clutch an the car turned on just fine and I kept on driving up untill this past Tuesday. The car would turn off on me while driving and now I was not able to pop the clutch and the car would have a harder time turning on once the car was sitting still for a bit.
THIS IS WERE IT GET'S INTRESTING!
I replaced the coil again thinking that I could have gotten a bad one! it worked ! for about 4 to 7 starts and it happened again. the car would not start.
I jumped on the forums and saw that some people were suggesting replacing the distributor. I almost bought an MSD distributor for about 300 + dollars when I decided to go with the motorcraft brand, I thought with my luck it would not work and I would be out 300 more dollars
5> installed new distributor > failed > the same issue, < I marked the old position old distributor to make sure I would not jack that up. KEY THING here ware that we still had no spark , spark was going into the coil but not out of the coil>
thought what are the chances that I could have gotten series of bad coils from autozone. I went to Oriley's and got thier 52 dollar coil > BAMMMM !
my car started with out a problem on the first try.
Been driving it to work and it has not shut off on me either.
I hope this helps some one, just based on "MY OWN" personal expirience, I will not be buying coils from autozone again. I will not go cheap when it come to the coil again.
