well i just finished getting my car all back together and i cant get it started. itll turn over and almost want to start but no go
dist is in 1 @ TDC (stabbed it in when i had it torn down to the shortblock) ive tried turning the dist a little to the right and left while cranking and hasnt made a difference. smells like its getting fuel, pretty sure its getting spark.
it was cranking over kinda slow so i have a battery charger on it now.
all electrical connections are good, tripple checked everything. good grounds.
i also swapped in a 5speed to replace my AODE, swapped computers too... could i possibly have a bad computer?
ahhh i just wanna drive my car again
dist is in 1 @ TDC (stabbed it in when i had it torn down to the shortblock) ive tried turning the dist a little to the right and left while cranking and hasnt made a difference. smells like its getting fuel, pretty sure its getting spark. it was cranking over kinda slow so i have a battery charger on it now.
) but just reverify where everything's at. I don't know how many times I've seen guys say the stang won't start after a big project like this, and it's always timing it seems.
That's true. Brandon (bjl95mustang) and I both had that same problem. If you have stud mount heads (which most aftermarkets are) then you need to make sure the rockers aren't too tight. How tight did you get them? I tightened mine 3/4 turn past zero lash and the car would hardly run. Loosened them up to 1/4 and it ran a lot better. You could try a compression test real quick, and that will tell you if your valves are sticking open. If you turn up good on compression, then you know it's either fuel or spark (sounds like it's not spark). Did you check to see if the coil is firing? Do you have spark at every wire? Checked fuel pressure? Do those things, then let us know what turns up. Good luck bud! I know you're anxious to drive that beast now.
