OK, here is what I have so far for my carb conversion:
- rpm air gap intake
- holley 750 carb
- msd distributor
- cartech fuel tank pickup
- holley blue fuel pump
- holley fuel pressure regulator
- in line fuel filter
- 20' of braided stainless steel fuel line
- hose mounting clamps
- 3/8" NPT <-> -8 AN adapter for pickup supply line
- 1/4" NPT plug for unused pickup return line
- other -8 AN fuel line fittings for fuel pump, reg, and carb supply lines
- air filter housing
- air filter element
- lokar throttle cable
- lokar kickdown cable (comes with AOD lever)
- lokar cable bracket (for both cables)
- holley carb AOD kickdown lever
- studs for carb
- intake <-> heads gaskets
- carb <-> lower gasket
- carb <-> air filter housing gasket
what else do i need as far as parts?
i think i am almost ready to start tearing stuff out ...
- holley 750 carb
- msd distributor
- studs for carb
