Carb conversion checklist ...
BlackVert
5,589
9
98
Bethesda, MD
OK, here is what I have so far for my carb conversion:
- rpm air gap intake
- holley 750 carb
- msd distributor
- cartech fuel tank pickup
- holley blue fuel pump
- holley fuel pressure regulator
- in line fuel filter
- 20' of braided stainless steel fuel line
- hose mounting clamps
- 3/8" NPT <-> -8 AN adapter for pickup supply line
- 1/4" NPT plug for unused pickup return line
- other -8 AN fuel line fittings for fuel pump, reg, and carb supply lines
- air filter housing
- air filter element
- lokar throttle cable
- lokar kickdown cable (comes with AOD lever)
- lokar cable bracket (for both cables)
- holley carb AOD kickdown lever
- studs for carb
- intake <-> heads gaskets
- carb <-> lower gasket
- carb <-> air filter housing gasket
what else do i need as far as parts?
i think i am almost ready to start tearing stuff out ... :banana:
- holley 750 carb
- msd distributor
- studs for carb
Thanks Blackvert, been thinking 408 carbed here, the list is helpfull, I would'nt go carb setup with a 302 for a street car, but 351 makes up for the loss of torque:nice:
- holley 750 carb
- msd distributor
- studs for carb
Can you add sell your fuel injection harness to me to your list??
May I suggest using the black XRP or russel socketless hose. It is much lighter, WAY easier to bend and put the fittings on, and about half the cost. I used this3-4 years ago and I have never had any leaks/cracks and my car sits outside 365 days a year. I ran the socketless hose all the way to the regulator then used all the stainless braided under the hood for the "look."
i have decided to go with black 3/8" fiber reinforced rubberized fuel line and nipple fittings. that stuff is much easier to work with, i can get it locally, and it costs a WHOLE LOT less than the braided hose and AN fittings.
home depot has the fittings for $1.75 a piece.
and the 3/8" stuff lets me use any of 100 or so fuel filters, whereas summit has about 5 filters for the -8AN stuff, starting at about $25 each
and did i mention that it doesn't have that red and blue anodized fittings? i have a black and silver theme going under the hood ... red and blue anodized parts have no place there.
