Typically EFI is up on torque and carb is up on peak hp, but that wasn't my point. I'm saying dollar for dollar it's no contest. If we both started out with the same budget of money and could spend it any way we wanted, my combo would probably be running nitrous while the EFI combo barely has enough money to complete the setup. Carb technology has come a long way since back in the day. Anymore it comes down to what you want out of the engine. If you want fuel economy, you can get a carb that will give you mpg that rivals EFI. If you want all out power then either combo will suffice as long as you've got the cash to make it work. Also there is more to tuning a carb than tuning it for WOT or for cruising....the problem is people bash carbs when they wouldn't know an accelerator pump from a booster if their life depended on it.
There are basically two things that are going to be the facts with this comparison and not much is ever going to change it.
Carb: cheaper, slightly less efficient
EFI: expensive, slightly more efficient
As for tuning, everyone says EFI is the easiest....i guess so if all you do is drive your car to the dyno and pay someone to tune your car. That must be pretty easy
If a guy takes the time to learn about a carb, and needs to do a few mods and ends up needing to tune, it's a simple matter of turning a few screws and changing the jets and you're done, not only in a fraction of the time it takes to get you back on the road as an EFI tune, but at a fraction of the cost. Hell i can retune AND rebuild my carb for as little as $50....how much is dyno time these days?
Also....if you want the best of both worlds....invest in an AF meter for your carb setup. Then you can monitor what the carb is doing while the car is running. You still have to make the changes yourself, but once it's dialed in there's nothing more you need to do.
