Ok man, i hate to do this, but this statement tells me you don't know all that much about carbs....so i'm sorry ahead of time but here's why. Just because a carb is a 'double pumper' doesn't mean it's going to have worse gas mileage than even an 850 with vacuum secondaries. What double pumper means is that the front and rear bowls have their own metering pates and
fuel lines hence double pumper. Both carbs have secondaries and if they were both vacuum secondary they would operate the same way.
Here's another one for ya....my car has mechanical secondaries as opposed to vacuum secondaries. A lot of people think that means it's going to get worse mpg.....wrong again. The reason is, i can feel the secondaries through opening through the extra effort it takes to push the gas pedal, whereas a vacuum secondary carb will open any time the vacuum supplied to it exceeds the force of the spring that's holding the diaphram open....meaning every time you take off too quick or go up a hill, or pretty much all the damn time in an automatic. I could drive my car 100 miles and never open the secondaries, which basically means i'm only running on 2 barrels which gives me better (although admittedly still not fantastic) mpg.
I will say this though....my 'stang still get around 16mph on the highway, and my '98 Cherokee gets exactly the same with an inline 6....and that's with 4.10s and low profile tires all around vs. an engine with less cylinders, less cubes, lower gear ratio and taller tires. It's just an example that EFI doesn't necessarily equal mpg either.
And btw if your carb motor is only getting 10mpg, you must be running 4.56 gears and an 1150cfm Holley Dominator
