D.Hearne
Ditto, replace the dual advance with a single. ( parts houses still stock these) As for the difference between the Ignitor I & II, the only thing I noticed was the II unit didn't develop a miss after a "hiccup" backfire thru the carb. The "I" did and required rebooting ( turning the ignition completely off) and restarting. As for performance, they're both the same, I can't tell the difference. Bad points? It won't start, hard starting,etc. Just what your problem is now. A good set of points will last you a year at most and require periodical adjustment to keep in tune. Pertronix ? Install it and forget it.
Could not wait - tried what you said and it fired right up.. Hooked coil to battery - fired up instantly!! Where do I send the check? Having a cold one right now to celebrate - this one was definitely bugging me. I did order a new harness yesterday when I ordered the petronix. Hopefully that will take care of it - in any case I know what the root problem is now. This site is great, I appreciate everyone that posted help and I hope I can return advice to others in the future.. :SNSign:
