  • 2.3L (N/A & Turbo) Tech
CARB SWAP ?
  • Thread starter Thread starter bullitt77
  • Start date Start date Nov 22, 2006
bullitt77
43
france
Nov 22, 2006
  • Nov 22, 2006
hi there !
on a 1979 2.3L mustang ( y code engine )
did someone has ever swap a the carb by something else ?
i've big problem with mine and i would like to found another carb ..... maybe without all this mess of vacumm outlet i have on mine
my problem is that it run very well but with 20 liters for 100 km ..... in us mesure it gives around 70 miles with 5.3 gallons
more ! : it run well with my my mixture totaly closed ...totaly lean ! ?
R
RustBucket
585
Buford, GA
Nov 22, 2006
  • Nov 22, 2006
If it runs better with the mixture screws closed, then fuel is getting in from somewhere else. Check the float level and the general condition of the float and the needle valve.
Chewievettte
32
Caledonia, MI
Nov 22, 2006
  • Nov 22, 2006
Judging by your location, throwing parts at it isn't an option so you might want to do some serious trouble shooting to find the problem.
mg man
142
  • Nov 22, 2006
I agree with rustbucket fuel getting into engine somehow. Not real familiar with carb type.Cheaper to fix. esslingerracing.com has some intakes for differant types. Made for racing not inexpensiveand won't met pollution laws but then again changing to differant carb will not either.The other possibility is to convert to newer efi from a donor vehicles if avaiable. sorry not much help.
bullitt77
43
france
Nov 23, 2006
  • Nov 23, 2006
buying parts for it , isn't a problem , i buy a lot of parts for my 69 .
the float are ok , that what i've sink about : gas must come from another way ... but where ? , i've dismantled the carb , put new seal ... nothing change!
too hard to find an efi from another vehicule
i'm good to have a look at esslingerracing
i've look at summint racing , htey have 2 barrels carbs , but are going to bolt on my intake ??
Chewievettte
32
Caledonia, MI
Nov 23, 2006
  • Nov 23, 2006
As long as the cfm is similar and its the same basic type it shouldnt be much of a problem. An adapter plate may be required but a good machine shop can cut that for you.
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
A
Carb swap question
  • AA wALtZ
  • Jul 27, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2024
General karthief
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
