Carburetor mount hoist bracket - strong enough?
  • Thread starter Thread starter car_kent
  • Start date Start date Dec 19, 2004
First Prev 2 of 2
reenmachine
20+ Year Stangneter
Jun 27, 2004
1,258
Montrose, CA
Dec 21, 2004
#21
  • Dec 21, 2004
  • #21
Just a point of interest that's semi-pertinent to this topic...
If you have 3 full threads engaged, the joint is as strong as the material it's threaded into. That is, you're not going to strip the threads out of the hole. We had to do this analysis back in engineering school, and then we did the actual tensile testing to failure to show it. It's actually like 2.88 threads or something like that. The "minimum 3 threads" thing is a rule of thumb used throughout engineering design, and of course margin guidelines suggest using a multiple of this, depending on the application.
Even if you've got 1000 lbs. of drivetrain hanging there, that's 250 lbs. per bolt, which really isn't squat when you consider that a grade 5 5/16" bolt fails in tension at about 6400 lb. and a grade 8 5/16" bolt fails in tension at about 8000 lbs.
The whole point of this dorky treatise is that you don't need to worry about finding a way to get an inch of engagement. Carb plates do look sketchy, but they're fine. Take note that most of the people saying that they're dangerous are those who haven't ever used one.
First Prev 2 of 2
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
M
Gifted a Junk 1976 Mustang II with plans for a radical conversion!
  • MXGerry
  • Apr 29, 2025
2K
1974 - 1978 Mustang II Talk & Tech Mar 12, 2026
MXGerry
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
