Car's Done!! New Pics!!! New Problems :(
  • Thread starter Thread starter Venom351R
  • Start date Start date Jul 16, 2008
  • 3
First Prev 3 of 3
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jul 19, 2008
#41
  • Jul 19, 2008
  • #41
Redline_351R said:
Wish I had known all of that before hand
I just went down to the garage after it sitting from 4:00 yesterday and there's still about 5 small drops ( about quarter size) of oil. not sure if that's what was left that may have just dripped off the back of the motor or not. I put my hand down on the lower intake and I can feel where the RVT bead is but I did not notice any new oil seeping out. I'll tke it out later today and see how it is from there.
Since the leaking seams to be less, try for the next couple of days to drive it a little, clean any residual oil you can feel/find, and repeat. Keep checking floor and areas that you checked/cleaned previously.
Good Luck.. Im right behind you!
RC
Venom351R
4,548
41
98
MAINE
Jul 19, 2008
#42
  • Jul 19, 2008
  • #42
RC
I hope its just what was left running off he said he used a ton of RVT on it so it should not leak. It was pooling up and dripping off the back of the motor before, hopefully its just oil that was pooled up before hand that ran down b/c when I go up my drive way its pretty steep so maybe it was enough to let what ever oil was left there drip back.
Cant wait to see yours up and running again. Its going to look sick!!! Next year I'm going to powder coat all my accessory brackets black so it matches the TFS Intake and run some aluminum pulleys.
blksn955.o
3,263
st.louis mo 314
Jul 19, 2008
#43
  • Jul 19, 2008
  • #43
Powdercoating the brackets is 100% worth it...I love mine so nice and they stay that way.
The oil is probably just what is still running down. I remember reading that 1 drop of oil/atf will spread out to about the size of a nickle/qrtr. You could always hit it with a can of break clean (while motor is off and not worm of course). I had a rear seal on the t5 go out last summer and used some to clean the tunnel.
I am assuming it will be a little faster now...I would think the lower leaking would cause a little vacume leak ?
Venom351R
4,548
41
98
MAINE
Jul 19, 2008
#44
  • Jul 19, 2008
  • #44
considering the gap that the TFS-R has when mated up to the 351 there prob was a vacuum leak of some sort. I backed the car out of the garage and the oil that on the floor was very minimal 4 drops about a quarter size. I gave it a good wash even though they washed it as the shop but it was raining on the way home yesterday (Bald Nittos did pretty well) so it needed to be washed again b/c Im going to clay bar it and wax it in the garage after lunch.
I think powder coating the brackets will really make it look nice. I wont get to it this year Ive spent to much as it is and now that its together again I want to keep it that way and enjoy it. Post up some pics of your brackets that are Powder coated.
blksn955.o
3,263
st.louis mo 314
Jul 19, 2008
#45
  • Jul 19, 2008
  • #45
dark and half way crappy pic...I really need to take some new/better ones with the new digi cam.
You can see the brakets. I ground the casting marks down to help give them a smooth look. I also had the alt. coated chrome and the upper intake/elbow I smoothed the snot out of and had coated the same color as my brackets...silver metalic.
Venom351R
4,548
41
98
MAINE
Jul 19, 2008
#46
  • Jul 19, 2008
  • #46
That looks much better then stock.
I'm beat I washed the car this morn the put it in the garage and clay bared it, pre waxed then carnauba waxed it, looks good though
Methodical
1,192
11
59
Clinton, MD
Jul 19, 2008
#47
  • Jul 19, 2008
  • #47
Redline_351R said:
Im not sure if the covers are for a carb or not, it does not say on the summit site but I have seen them in the carb section of VC in Mustangs Unlimited Mags. I still have the PCV hooked up, Its only 1 breather that Im running.
I had cobra VC's on it before and it cleared my 1.7's
Were the Cobra VCs (assuming they were the non-stock ones) the same height as the ones you have on there now? Also, were your 1.7s stud or pedestal mounts at the time? Just trying to get some info because no one I talk to can give me any definitive answer. Even when I call FRP tech line they don't seem to know or at least act like they don't know any specs (measurements) of the valve covers. I hate to buy them and have issues.
Thanks for the info.
Venom351R
4,548
41
98
MAINE
Jul 19, 2008
#48
  • Jul 19, 2008
  • #48
They were the regular stock Cobra valve covers for 94/95 The ones I have on there now are much taller. They are stud mounted rockers. These ones exactly.
Trick Flow Specialties TFS-51400521 - Trick Flow Roller Rocker Arms - summitracing.com
94GTLaserRC
11,178
Jul 19, 2008
#49
  • Jul 19, 2008
  • #49
Shoot Mansonozz a PM on that if you dont have someone. Just make sure you do as many parts as you can at once so can save some Money.
Good Luck
RC
Venom351R
4,548
41
98
MAINE
Jul 19, 2008
#50
  • Jul 19, 2008
  • #50
Good Luck
RC
Yeah hes close by to, maybe I could even meet him somewhere at a show or something to.
Took the Mustang into town today and got home and parked it, checked under it after a few hrs and no oil drops
94GTLaserRC
11,178
Jul 19, 2008
#51
  • Jul 19, 2008
  • #51
Try wiping down any residual underneath and keep repeating...A good sign is less oil each time, if not no oil.
RC
Methodical
1,192
11
59
Clinton, MD
Jul 20, 2008
#52
  • Jul 20, 2008
  • #52
Cool. Thanks got the info I needed
Venom351R
4,548
41
98
MAINE
Jul 20, 2008
#53
  • Jul 20, 2008
  • #53
RC
Seems to be the case, its been less and less and I belive its down to none now.
awesome, hope it all works out
I
inphiniti
412
Providence, RI
Jul 20, 2008
#54
  • Jul 20, 2008
  • #54
so u gonna race @ FFW or just Tasca Day? i dont think my car will be coming up for FFW... just tasca day when i plan to race...
Pokageek
2,767
MA, USA
Jul 20, 2008
#55
  • Jul 20, 2008
  • #55
Tune it before you race it Red... Cheap insurance right?
Venom351R
4,548
41
98
MAINE
Jul 20, 2008
#56
  • Jul 20, 2008
  • #56
Im racing it this friday, not sure when it will be tuned yet. Its not as important w/ H/C/I as it is w/ a S/C as far as tune. I am getting it done but if anything its running really rich. My gas mileage sucks and I can smell unburnt fuel often. Its already been ripped pretty hard in second and third gear no less then if I was at the track.
Id like to to FFW but I have to get my longer wheel studs put in b/c Im not racing w/ my Nitto's for an event. Im deff doing Tasca day b/c Im off that day anyway. Im going to try and also do it for FFW but I'll be there either way.
gcomfx.com
3,690
Republic, MO
Jul 21, 2008
#57
  • Jul 21, 2008
  • #57
Sweet.... 8)
Zero_chance
1,244
Maricopa, AZ
Jul 21, 2008
#58
  • Jul 21, 2008
  • #58
Yeah Im going to the FFW in Epping too. Id like to see your car in person. I definitely wont be racing though. Whens Tasca day?
Methodical
1,192
11
59
Clinton, MD
Jul 23, 2008
#59
  • Jul 23, 2008
  • #59
Redline, one more ? Do you have an intake spacer on the car to clear the VCs. If so what size do you have? I'm ready to purchase them as they are the only black ones Ford has that will clear the stud mounted rockers. Just wanted to make absolutely sure because the place I get some of my parts won't give refunds, only store credit.
Again thanks
Venom351R
4,548
41
98
MAINE
Jul 24, 2008
#60
  • Jul 24, 2008
  • #60
I think its oct 18th but dont quote me on that. I'll be there for FFW, hopefully doing some racing.
Again thanks
sorry for the longer delay Ive been on vacation. I bought a 1" spacer but didnt need it. its a CLOSE fit but it did work w/ out the spacer.
  • 3
First Prev 3 of 3
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
