windsordeath
LOL! was I getting an ass chewing? Thanks for the prompt reply man.. I have checked and confirmed both engine to body grounds.. at the drivers motor mount..they are clean,dry and properly secured. All connectors under the Battery Junction Box are plugged in, also i have since removed them and checked to see if pins were pushed out or damaged/corroded.. reinstalled them.. I have cleaned all three ground eyelets on the core support and even went as far as replacing a questionable negative terminal which brought my Ohms down to a more acceptable level of .01 at the CCRM/PCM eyelets...
Currently as of this morning I have procured my CCRM pinout from a friend and some PCM power distribution stuff from a EVTM, but nothing that was showing me what was powering fuse 2.2 and 2.8 Thank you for clarifying that.. I was thinking that the EEC relay wasn't energized but wasn't sure if I was headed in the right direction..
PRAY FOR THE FALLEN
