centri blower guys HELP me out with compression!!!!
whitestang! ive been waiting for you! love your car btw. anyway, yea you went with 8.5:1 and have alot of lowend power? that is awsome because if that is the case i will go that route for reliability.
i assume i will be putting out around 500rwhp.
this makes me super happy because i want to get what my tuner feels comfortable with but i didnt want to get it if he was wrong about the 8.5 compression.
white stang, if you are at 2000 rpm and get on it, does it instantly break them loose or does it take some time and rpm before you blow them off?
And also remember, whitestang has a RR intake....those are NOT at all for lowend power. High end HP intakes. So wait and see what he says, and you can be assured that you PI will have even more lowend grunt...but not the highend power of his.
You know man, alot of things sound bad on paper....but in the real world you often discover that what "everyone" says is either completely wrong, or a streatched truth. I have seen this COUNTLESS times from what people tell me.
Not saying this is the case, but just from what I have seen.
i hear you hotmustang! i also not saying this is the case here. however, people are making me think the car might have a weaker lowend then i have now if i go 8.5. im not trying to have that with a blower. i want to pick up all through most of the range even with the 8.5 compression. even if its just a little more power in the lower and alot more in the upper. somthing gained down low is better then nothing.
if what whitestang says is true and he has plenty of lowend with the 8.5 then that is obviously the best case senerio.:nice:
im going to talk to my tuner tomorrow in person to tell him what people are saying about the 8.5. i want to hear his response to having no low end on 8.5.
im gonna tell him that most people are saying stock compression with the centris.....ill let everyone know what he says weather they agree or not. just to spread different points of view.
i will see if he thinks he can tune the 9.2 and how safe it would be.. im assuming that is his reason for not liking 9.2.
well, my tuner said that i could go either way. he still would rather me go somewhat lower like 8.7 - 8.8. he said that the 8.5 leaves me room to raise the boost. he said if im not going to go higher then 15psi then the 9.2 would be fine, he can tune with it.
i did forget to ask him about the reliability of 9.2 compression.:bang:
he mentioned that i would only make 20-30 more hp by going with 9.2 then 8.5. however, with him that is peak not in the lower end.
Here is a pretty good article for you to read to add a little more complexity to your decision :).
[SIZE=+2]Compression -vs- Boost[/SIZE]
[SIZE=-1]Almost as fast as a supercharger can be bolted on, the question of how much boost can be run is instantly a concern. When building up a motor to be supercharged, you've also got the question of just how much compression to run. Both of these questions relate to essentially the same set of equations. Assuming that all of the other requirements of the motor are satisfied, the compression -vs- boost aspect is not all that difficult.
The only way to make more power is to increase cylinder pressure and burn more fuel. The main purpose of the supercharger is to supply the motor with a more dense air charge, which allows for the ability to burn the additional fuel. By adding a supercharger, additional air should no longer be a problem. Ensuring that there will be enough additional fuel to maintain the proper air to fuel ratio will be the key to using the maximum effective compression.
All motors have a static compression ratio. This is the amount that the air inside the cylinder is compressed. It is a ratio of the cylinder volume at BDC to the volume at TDC. When a supercharger is added, additional air is forced into the cylinder effectively raising the compression ratio. The result of this is called effective compression. The formula for finding the effective compression is very easy:
((boost psi / 14.7) + 1) x motor compression = effective compression.
The effective compression allows a supercharged motor to be compared to a normally aspirated motor. For the most part, a supercharged motor with the same effective compression as a (similar) normally aspirated motor with the same static compression should have about the same overall power.
This may bring up the question that if the overall power should be about the same, why go with a supercharger? The main advantage of the supercharger is that it allows for a moderate compression level during normal driving while allowing for very high compression levels when needed. Obviously a high compression motor of about 14:1 makes a lot of power, but it would never survive daily driving. A lower compression motor is great for daily driving, but greatly reduces the potential for power. The supercharger allows for higher compression levels than could be used without a supercharger, while still offering the benifits of a standard compression motor. Many street supercharged systems will go beyond 18:1 effective compression under boost. Under race conditions, many supercharged race motors will go well beyond 22:1 effective compression. Both of these levels are far beyond what could be done reliably or cost effectively without a supercharger.
This brings us back to the question of just how much boost or compression can be run. Obviously there can't be a simple number that could be used for every application. This is why it's so critical to chose the proper components. It's not necessary to build a low compression motor to use a supercharger, but the correct parts are still necessary. The biggest factors will be in things like head bolts (or preferably studs), gaskets, and the strength of the other engine components. It goes without saying that the incredible power that a supercharger can add, can easily start breaking things. It is very important that as the boost levels rise, the need for a stronger crank, rods, pistons, etc... becomes very critical. Many people forget this as the motor itself is relatively mild, while the supercharger pushes it well beyond the practical limits it was intended for.
Now, back to the compression issue. Anyone who has looked into supercharging has heard that you need a low (static) compression motor. This may have been true once upon a time, when roots type (positive displacement) superchargers ruled the land, but it's not so necessary now. The problem with a low compression motor is that it relies heavily on the supercharger for its power. An 8:1 motor is definitely not going to be a power house. Sure, you can throw 18 lbs of boost on it and get some real power, but why? A higher compression motor of 9.5:1 will have much more power without the blower. Then, with less boost you could easily have the same overall power - only it would be much more usable. Both of the motors (8:1 with 18 lbs boost and 9.5:1 with 12 lbs boost) will have almost the same effective compression and about the same overall power. The big difference will be where you see the power, and how much of a demand will be placed on the supercharger. Obviously, the 9.5:1 motor is going to have far greater torque and low end power as the boost is only starting to come in. It is also going to be much easier to find a blower to survive only 12 lbs of boost -vs- one that would have to put out 18 lbs. It is now very easy to see why a higher compression motor with lower boost is becoming so popular.
Please understand that when I say higher compression and lower boost, there are limits to each. Going over about 10:1 will make the amount of boost that is usable drop quickly to the point that the supercharger is somewhat wasted. In my opinion, anything less than 8 lbs of boost is a waste of a supercharger. Going over 10:1 will also make daily driving with pump gas much more difficult. In this same way, compression levels much under 9:1 will require substantial boost levels to make massive power gains. This would require boost levels that are very demanding of a supercharger. This is truly unnecessary. This isn't to say that the lower compression / higher boost set-up doesn't have a slightly higher potential for power, because it does. A lower compression motor has the ability to contain more volume. This can be an advantage, but is such a minor one that it's not necessarily worth the effort - unless it's for an all out race motor. Even then there are limits for the same reasons as the street / strip motor.
Once again, the compression -vs- boost issue. For a car that will see the streets (actually for most applications), the best thing to do is start with a motor compression that is high enough to make the horsepower you want for normal driving. Don't rely on your supercharger to make all your horsepower. With a good motor compression, add as much boost as is safe for your particular application. Decide on a final effective compression, and work your way back through the formula to find your maximum boost level: ((effective compression / motor compression) - 1) x 14.7 = boost. With the proper fuel system and related engine components, an effective compression of 16:1 to 18:1 should be more than workable. For heavily modified cars, effective compressions over 20:1 should be very carefully considered. Remember, even Indy cars only run about 18 Lbs of boost and reasonable static compression levels. Technology has come a long way and modern day supercharging should take full advantage of this.
While these opinions are not exactly the most popular, they are based on facts and real world performance. While there will always be those who continue with tradition and stick with what was done in the past, it is those who reach for something more that are winning races. Often times, some of the best advice can be found from those who have done what you want to do. All too often it is those who know the least that offer the most advice. After having been involved in supercharging for many years, I have heard it all. Most of it was worthless. It was often the least mentioned things and trail and error that have been the most rewarding. Hopefully this information will help to explain some of the often misunderstood aspects of supercharging.[/SIZE]
ambo, i go to radical racing in acto...south jersey.
jstreet, thanks for that article. it was very interesting. however, i ordered my engine at around 4pm to day from vt engines before i saw the acticle you posted.
not saying it would have changed my mind or anything.
so i after talking to my tuner at radical who said that i could go 9.2 but not run much more boost then 15psi, i talked to jim at vt.
jim assured me that 9.2 compression would be fine for my 15psi application. he said that the engine is strong and will last a long time.
so i ordered the vt stroker engine with 21cc pistons for 9.2 compression. i got the 7qt oil pan for that as well.:nice:
:nice:
Best thing you could do...talk with Jim or Scott, I honestly would do just about whatever they said to do motor wise lol.
And that was a big concern of mine....potential boost increase. But if your sure your not going over 15PSI then hey, get whats best for you now :nice: . Your going to have ALOT of lowend grunt....that stroker is going to help alot.
Im also probably going to go the same route down the line....stroker to help the turbos spool up faster :D CONGRATS MANG!
one of my buddies bought his motor off of vt. he had an initial failure(not an assembley error either) but those guys took care of it right away. they are seriously bad asses...
well except for scott :D
thanks guys, all of you for helping me decide what to go with.
yea i think between the compression and the stroker it will feel pretty good down low.
warrior, one step at a time. this is only the first part i purchased. i still have to get all the blower components and the blower itself, fuel system, and intercooler + gaskets and all the little things.
this wont happen until summer at the earliest. i need to come up with some serious funds.:shrug: im just going to collect parts as i go:nice:
should be awsome once complete....i cant wait!
thanks again everyone.
what blower? i would definitely skip ahead and get a n2k or t trim. although s trims can be found so cheap and easily get you up to around 600rwhp with the setup you are putting together
edit: doh nevermind read your sig
hotmustang331 said:
I dont know, its what I would do....but he can do whatever he wants.
15PSI is going to make some heat, even with an IC. And like SVT says EVERYONE will get greedy and want more later on....I wouldnt want to limit myself for a bit more power right now.
But eh, thats my opinion...im the type of guy that always plays it safe....well almost always :D .
I have yet to see somebody build a setup and stick with it.. give it 6 month he will want to up that boost a few pounds. If this was my money and my motor I would leave a lot more overhead than going 9.2.1
