changing spark plugs soon
  • Thread starter Thread starter fivespeedsteed
  • Start date Start date Nov 5, 2005
1 of 2 Next Last
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Nov 5, 2005
  • Nov 5, 2005
anything i should know in advance? also im doing oil, so should i change the filter? it looks kinda new but i have one, i just need to get anoter quart to do it. i got a little catch pan that holds 6 quarts, a socet that fits the plugs, and a socet extension that bends to a 45 degree angle or whatever. thanks.
HISSIN50
34
129
Nov 5, 2005
  • Nov 5, 2005
DO change the filter. FL1A is my choice.
I like to use a box end wrench on the bottom drain bolt or else I end up with oil all inside my ratchet.
Dont forget the front drain. Good luck.
HISSIN50
34
129
Nov 5, 2005
  • Nov 5, 2005
For plugs, a ratchet, long and short wobble extension and an air tool swivel universal joint are what I use.
I like to put anti seize on the plug threads and dielectrical grease in the plug boots. Dont forget to check the gap on all the plugs and gap accordingly (in case a plug got dropped at the store, etc). Spec is 0.052- 0.056"). And Autolite 25's are for a stock application. I stay away from Platinum plugs on a 5.0L EFI motor.
Good luck. Sounds like it is your first time. Congrats on doing it yourself and dont be bashful about posting if you get stuck on something.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 5, 2005
  • Nov 5, 2005
Put a drop of oil on the threads of each plug or use some anti-seize stuff if you have any.
legalize420
1,541
South Florida
Nov 5, 2005
  • Nov 5, 2005
put some oil on the rubber ring seal of the filter where it meets the block
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Nov 5, 2005
  • Nov 5, 2005
Make sure you buy beer too
RacEoHolic330
4,014
1,698
203
Allentown, PA
Nov 5, 2005
  • Nov 5, 2005
:Word:
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 5, 2005
  • Nov 5, 2005
I take it this is your first oil change, don't forget there are two oil pan plugs that need to be removed to drain all the oil.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 5, 2005
  • Nov 5, 2005
yeah dont forget about the back plug
the 1st time i changed my oil i got confused when only about 1qt came out... then i noticed the 2nd drain plug
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Nov 5, 2005
#10
  • Nov 5, 2005
  • #10
this back plug (one closest to the passengers and drivers of the car is on the oil pan ? will i be able to see it okay, im sure im finding the front one but where is the back one? thanks for all the help.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 5, 2005
#11
  • Nov 5, 2005
  • #11
Once the car is up on jackstands or on ramps you will be able to look over the oil pan and find the plugs. DO NOT DO NOT TRUST THE CAR IF RAISED AND BEING HELD ONLY BY THE JACK!!! if you don't have the jackstands or ramps save your self some serious injury and take the car to jiffy lube. Provided you do have the ramps/stands make sure you get that pan in position under the oil filter when removing it, remember it's full of oil and will make one god awful mess if the pan is not positioned properly. Also make sure to apply some oil to the gasket on the filter so assis prior to install. Gap your plugs at .054 or very close to with a plug gap tool, if you don't have one, spend the 5$ and get one.
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Nov 6, 2005
#12
  • Nov 6, 2005
  • #12
don't forget to put the new oil filter on before you start it up..... i didn't on my tempo 3 weeks ago (lol theres a story to this)
fivespeedsteed
20+ Year Stangneter
Oct 17, 2003
748
22
69
Richmond, VA
Nov 6, 2005
#13
  • Nov 6, 2005
  • #13
its not even going off the ground but i gotcha.
I_AM_CANADIAN
189
B.C.
Nov 6, 2005
#14
  • Nov 6, 2005
  • #14
you have my attention.... (since this guys question has already been answered)
DmnStr8
NH
Nov 6, 2005
#15
  • Nov 6, 2005
  • #15
Tighten the new filter till it is hand tight then just one 1/4 turn more. Makes it alot easier to take off the next time.
Some people fill the filter first, to prevent low oil pressures at start. This trich has always resulted in spilled oil for me.
If the filter won't come off and you have no way of getting an oil filter wrench (assuming you don't own one) you can drive a screw driver through the filter to help get it off. Use this as a last resort, cause its a major PITA if this one ****s up.
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Nov 6, 2005
#16
  • Nov 6, 2005
  • #16
I always pull the coil wire off and crank the motor for 5-10 seconds to fill the filter with oil. Then i put the wire back on and start it
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 6, 2005
#17
  • Nov 6, 2005
  • #17
I see the future...I see a huge mess in your fathers driveway...Sounds to me like you could/should just pay the extra 10 and let a lube place do it, leaving the car on the ground is going to be a huge pain in the ass. No harm in it, I take the wifes 04 gt in to the 10minute place, and my truck as well..too much hastle.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Nov 6, 2005
#18
  • Nov 6, 2005
  • #18
the drain plugs are RIGHT THERE, you wont have a problem finding them
plugs are easy also. Make sure the plug is al the way in the plug socket before putting them in, failure to do so results in a broken plug.
fox-gt
204
TN
Nov 6, 2005
#19
  • Nov 6, 2005
  • #19
When I did my first plug change on my 93, I had to remove the air tube from the throttle body to get to the back spark plug.
I don't do my own oil changes, $14.99 at goodyear and I'm out in about 15 minutes.
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
Nov 6, 2005
#20
  • Nov 6, 2005
  • #20
long story short. i drained the oil, took the filter off, and left the drain plug out so i could do the plugs and let the rest of the oil drain (i always do this) theni noticed my alternator wire looked loose, i wiggled it and the plug and electrical stuff fell off the alternator, it was really badly coroded. so i went to the junkyard got a new alternator, came back put it on, put the darin plug back on. and forgot about the filter cause of my little adventures. started it up, the oil light wouldn't go out. i said "WTF" so i get out only to find a nice big puddle of oil under the car. good times
1 of 2 Next Last
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
