Changing struts-FYI
mustang462002
89
FYI
Guides on here say you can do it without an impact wrench. You can't. I tried everything from a big bar and a wrench to cutting the nut off. Either way you need the impact wrench.
It took me 5 trips to different stores to find an affordable electric impact wrench. Made life much easier.
FYI very important. Tokico HP struts have a nut that is bigger than stock struts. You need a special size not usually found on kits.
This install was stupid hard because of the impact wrench.
I've done all the mods in my sig with hand tools. That nut was ridiculously hard to get off, but with an adequate supply of WD-40 and elbow grease, it came off with a wrench and large screwdriver through the slot to keep the strut shaft from spinning.
