Cheap Modifications...
  • Thread starter Thread starter Strype
  • Start date Start date Aug 9, 2006
1 of 2 Next Last
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 9, 2006
  • Aug 9, 2006
Okay, so MyBad70 got my electric fan on last night and I was thinking, what else can I do to this car for cheap horsepower? So I'm making a list of what I have.
Air Silencer Removed
K&N Cone Filter
Timing Bump from 10-16 degrees
TPS set to .99
Short Belt to bypass Smog Pump
Electric Fan
FlowMasters
H-pipe
After Market Tail Pipes
Delete Hose from Valve Cover to Throttle Body
70mm Throttle Body w/ blank spacer
76mm Mass Air Meter
65mm Explorer Intake w/ 1" spacer
3.73 Gears
Blaster Coil
Subframe Connectors
Underdrive Pulleys
Mickey ET Street Radials
I know I'm missing headers & roller rockers what else can I do for cheap w/o buying heads
Also, anybody got any dyno #'s or Track Times for a full bolt on car??? I refuse to take off the dogbone or the sway bar or change to drag shocks or springs
FSTRDNU
76
  • Aug 9, 2006
12.6 w/ slicks, with a cobra intake, stock cam, boltons, and slicks on a 3100 lb speed density hatch
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 9, 2006
  • Aug 9, 2006
So I could get into the 12's theoretically once I get it all put on?
RUNINAGT
237
CHARLESTON S.C.
Aug 9, 2006
  • Aug 9, 2006
Does it affect anything by bypassing the smog pump.. I think I remember doing that on my 86. Can I just install a smaller belt. Do you know what the belt part # was. Theres a tube going to the exhaust, do you just plug it off?? Mine is still operational, but I would like to free up some pony's as well, does it make that much of a difference?
I know a bunch of questions thrown in one paragraph.
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Aug 9, 2006
  • Aug 9, 2006
cam?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 9, 2006
  • Aug 9, 2006
Just makes your car a little stinky
Yep!
Hmmm... I had one underdrive on the crank. Go to autozone and just bug the hek out of them, that's what I do
Yep
You can tell
That's alright
88gt
794
Drillers cabin
Aug 9, 2006
  • Aug 9, 2006
Strype needs a cookie for being so efficient!!!!:SNSign:
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 9, 2006
  • Aug 9, 2006
88GT17MA
289
  • Aug 9, 2006
mud flaps
RUNINAGT
237
CHARLESTON S.C.
Aug 9, 2006
#10
  • Aug 9, 2006
  • #10
OK then I might attemp that this weekend. Im bringing it to the shop on Sat to replace rear wheel cylinders,(fluid leak @ backing plate on driver rear hope its just wheel cylinders and not axle seal.) I might just do it then.
Stype thanks for the answers.
FSTRDNU
76
#11
  • Aug 9, 2006
  • #11
my DD is a full bolton 119k stock 93 with unported e7's, and just about every bolton in the book, but i do have an e-cam
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Aug 9, 2006
#12
  • Aug 9, 2006
  • #12
How do i adjust the tps? and how does that help?
Aliate X
602
Rockland NY
Aug 9, 2006
#13
  • Aug 9, 2006
  • #13
I dunno if Id go with MT's for that setup.
R
Reed
78
BC, Canada
Aug 9, 2006
#14
  • Aug 9, 2006
  • #14
Hey, how does removing the tube from valve cover to TB add horses?
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Aug 9, 2006
#15
  • Aug 9, 2006
  • #15
Port your lower intake at home and gain some free ponies..
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 9, 2006
#16
  • Aug 9, 2006
  • #16
n a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD and you will need the u-joint, part #353 from NAPA. It should bolt right up after the u-joint swap.
*1.) I got a metal flange adapter from Powered by Ford for $35 and tax. That was over a year ago. Summit Racing may also have one too.
Powered By Ford
1516 South Division Avenue
Orlando, FL 32805
Hours 0800-1800
Phone 407-843-3673
http://www.poweredbyford.com/
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Aug 9, 2006
#17
  • Aug 9, 2006
  • #17
thats a damn fine post!
GreatWhite
232
Fairfield, PA
Aug 9, 2006
#18
  • Aug 9, 2006
  • #18
Is there anyway a 200amp inline fuse would harm or hinder the charging of the 3G system?
grey5.0beast
Aug 3, 2004
atl ga
Aug 9, 2006
#19
  • Aug 9, 2006
  • #19
got a 200 amp eh?
lol
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 9, 2006
#20
  • Aug 9, 2006
  • #20
Thanks for the replies guys
We have a saying in Alabama...
"The cooler the air- the hotter the fire"
"Fire" is pronounced "Far"
That is HOT HOT HOT air being sucked right into your throttle body my friend
It's not a hp adder, but it does increase throttle response. Goto Walmart and get a "Volt Meter" (yellow digital) from the automotive section. Place a pin through the Green (I think I'll double check the holes in mine) and through the black wires.
Now, place the meter on .20 on the dial on the right at about 3-4 o'clock.
Put the key in the ignition and place it in the on position.
When you touch the black meter wire to the black pin, and the red meter wire to the green pin, you should get between .90 and .99.
If not, shave the plastic off of the inside of the screw hole on the tps sensor until you can rotate it clock wise enough to get that reading.
PS: I've done it 10 times and still can't remember, I believe it's the green and not the orange, but search the site to make sure.
Whew
1 of 2 Next Last
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
E
1986 Convertable 5.0 GT
  • eneerg
  • Sep 24, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 24, 2025
ACT sensor in plastic charge pipe
  • 92Rustang
  • Jul 23, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2024
92Rustang
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
