Okay, so MyBad70 got my electric fan on last night and I was thinking, what else can I do to this car for cheap horsepower? So I'm making a list of what I have.
Air Silencer Removed
K&N Cone Filter
Timing Bump from 10-16 degrees
TPS set to .99
Short Belt to bypass Smog Pump
Electric Fan
FlowMasters
H-pipe
After Market Tail Pipes
Delete Hose from Valve Cover to Throttle Body
70mm Throttle Body w/ blank spacer
76mm Mass Air Meter
65mm Explorer Intake w/ 1" spacer
3.73 Gears
Blaster Coil
Subframe Connectors
Underdrive Pulleys
Mickey ET Street Radials
I know I'm missing headers & roller rockers what else can I do for cheap w/o buying heads
Also, anybody got any dyno #'s or Track Times for a full bolt on car??? I refuse to take off the dogbone or the sway bar or change to drag shocks or springs
K&N Cone Filter
TPS set to .99
Electric Fan
FlowMasters
H-pipe
76mm Mass Air Meter
3.73 Gears
Blaster Coil
Subframe Connectors
Underdrive Pulleys
So I could get into the 12's theoretically once I get it all put on?
