cheapest way to hit 300hp???
what is the easiest, simplist, and cheapest way to hit around 300 hp with a 2.3T from a merkur??? i figure exaust, boost valve, BOV, fuel pressure regulator?, better fuel pump (what should i go with?) intercooler, and what else would it take?
The stock computer, vam, turbo, and injectors all max out right around there. What that means is you'll need to port the head/intakes/E6 exhaust mani, full 3" exhaust, cone filter, a GOOD intercooler, and run 23-24psi...which will require a bit of race gas mixed in with the pump gas. You'll also need to run about 50psi base fuel pressure to get the stock injectors to flow enough for 300rwhp.
I'm hoping to hit 300 also, currently i've got
Aeromotive FPR
Walboro 255
Bobs Log
Gillis
Stingers Front Mount
35LB Injectors
8UA 88 TC Auto Computer
.63 Garrett T3
3" downpipe into 2 2 1/2" Duals with Dynamax Ultraflows and Stingers downpipe
Hopefully I'm close the A4LD I have has a complete rebuild with a shift kit and much much better cooler and will have synthetic fluid :nice:
no nitrous. i want the 300 hp, without relying on the bottle ya know?
Well you could build the motor up a little bit N/A but don't build it to the point where you can't use a turbo. You could use nitrous but you said no nitrous, water injection would help but it is sorta like nitrous but not as effective. I do not know if this artcle will help you but this got got 330HP out of his pony.
http://www.mustangmonthly.com/featuredvehicles/mump_0412_1986_ford_mustang_svo_modified_muscle_car/
Uh, it's already a turbo engine.
